diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   please HELP bourned Source resistor Aleph 30 (http://www.diyaudio.com/forums/pass-labs/32018-please-help-bourned-source-resistor-aleph-30-a.html)
wijgers 11th April 2004 10:40 AM
Hello,
Just applied 20V rails and burned two Source resistors.
The two resistors are conected at the negative rails, and burned within 10 sec.
Voltage is +- 21.4 V
There was no input conected
There was a 30 W 8 ohm resistor at the output.
Please help what could be wrong???????
Nils
MikeW 11th April 2004 02:11 PM
Short
You have a short. Check all transistors. Run the amp without a load. Most problems I have had are with the 9610's. I have a few extra if you need some.
Dennis Hui 11th April 2004 02:27 PM
Don't forget to check the NPN transistors and
make sure they're in the right way.
Good luck.
Dennis
wijgers 12th April 2004 08:35 PM
Found it!!!
Thanks for the replies, But It was me who made the mistake.
By mistake and uncarefull checking, I didn't conect R 18 to the colector of the current source MPSA18.
After a good check, I did another try, And it worked. No failures any more.
Listened to it I was Clear it make a defference. More AIR, very detailed, en bright.
So next thing to do is make a PRE and build a case for the Aleph 30.
Thanks again.
Nils
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
