I have an itch that needs scratching..
I can't find any info on untwisted multistrand wire, but I'm sure it exists.
Has anybody got any experience of this stuff, or how it compares or differs to/from twisted multistrand.
Cat5 cable is flat not twisted 6 core.
Twisted pairs are used for balanced line and telephony. Parallel wires are OK for DC but AC signal can give cross talk.
You wrote this too fast, as CAT5 is both NOT flat and also IS twisted...?
all the cat5 I have is twisted.
Scottjoplin had it, I meant all the strands within one sheath, as in speaker wire. There are sales references to it but I can't find any technical explanations or detail of the difference between it and the usual twisted strand stuff.
Cat5 is several solid core wires individually insulated, not multistand.
It aint no biggie....
I saw some advertised and wondered what the benefits might be so got curious and tried to find some detail. I got even more curious when I couldn't find any mention.
As this is only one of two forums that I use then I thought I'd ask here.
I'm guessing now that this may be purpose made for one seller, and other than it being available only as individual wire(need a pair for one speaker) the only benefit I can see might be low capacitance....
I will curb my curiosity.
Not all Cat5 is solid core, it depends on it's usage. For cables that move often you don't want solid core ...
Please show an example. Maybe I missed something, but all the cat5 I've seen used in audio is cat5 in the "plenum" version which uses Teflon insulation. It's configuration is 4 twisted pairs of approximately 22 gauge solid core. It is used extensively in construction for office computer and telephone systems.
It is also the type that a number of DIY type audio sites use for speaker wires/cables
Checking Wikipedia it in fact does state it is available in stranded or solid. I have never seen stranded used in any DIY audio purposes, but I am sure you could if you wanted to.
Russellc
Russellc
....It is also the type that a number of DIY type audio sites use for speaker wires/cables....
One example :
[TNT-Audio DIY designs] DIY audio cables
CAT 5 DIY Interconnects and Speaker Cable CookBook
Greetings 🙂
Also four pairs (eight cores not six).
Untwisted multicore is good for crosstalk, hum and RF interference. Most likely application is DC signalling.
- untwisted multistrand
