Medium Aleph 3 8ohm@20w.
Old 11th June 2018, 04:21 AM   #51
tonimxp is offline tonimxp  Italy
From my load tests I obtained the following results:
30w into 8 ohm
45w into 4 ohm
29w into 2 ohm
Can be Q9 current limiter manager that limit the power into 2 ohm?
Can i decrease its base resistor (R29) to 47 Ohm?
Old 11th June 2018, 06:12 AM   #52
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
if you're reaching twice Iq , be satisfied
though , nothing is preventing you to increase current limiting level (as you proposed) and measure results
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th June 2018, 12:02 PM   #53
Nag is offline Nag  India
Ok Thank you for ztx 450. R108 is for dc offset approx 0V and R113 is for increasing bias current. Am I correct ?.
Old 13th June 2018, 12:22 PM   #54
Zen Mod's Avatar
ref. to pdf I posted on previous page , yes
Old 16th June 2018, 06:48 AM   #55
Hi All,
The amp is ready but I am facing some strange issue.
1. left channel output voltage is around 23 volts. right channel 70mV. Right channel is working I played some song.
2. Replaced input transistors in left channel after that left channel output voltage is 0.1V and right channel is -23V. left channel working right channel not .
Am I connecting RCA wrong or anything .
outer layer is ground and center pin is signal I am I correct ?
Old 16th June 2018, 07:46 AM   #56
Zen Mod's Avatar
you're doing something wrong , if while repairing one channel you broke the other one
post pics of present situation
Old 16th June 2018, 08:50 AM   #57
Dear Zen Mod,
Sorry for messy wiring.I am posting my pics here.
Actually I didn't touched left channel After right channel repair problem reversed.
Old 16th June 2018, 10:20 AM   #58
somewhere some thing shorting. some times it is working.
Old 16th June 2018, 10:32 AM   #59
adason is offline adason  United States
adason's Avatar
You like spagetti?
Old 16th June 2018, 11:01 AM   #60
avtech23 is offline avtech23  Australia
WAF. The most critical value in audio!
avtech23's Avatar
Check under the board for anything loose or in contact with the board.
Isolate the boards (run one board only at a time) and see if there is cross contact.
Disconnect input sources and outputs and check the voltages on the board.
If it occured after disturbance, check everything you touched. Assume any wire you reconnected is in the wrong place until you satisfy yourself otherwise (prove to yourself with the schematic).
Tidy up the wiring. It will make troubleshooting easier for you - and all us spectators.
The ever growing project list.. NAP140 Clone | NAD 3225PE | VSQC Phunk Style | NAD 3020i | 2 Princeton Clones | JLH1969 | Retro 50W (Last in line)...maybe
Medium Aleph 3 8ohm@20w.Hide this!Advertise here!
63watt class A into 8Ohm, 110watt semi-class A into 8Ohm, @ 20Khz 3rd harmonic -90dB FdW Solid State 47 31st December 2010 04:05 PM
8ohm resistor in series with 8ohm speakers for a 16ohm OT? Reidy- Tubes / Valves 8 10th January 2010 11:25 PM
Large Cone/large VC or several medium sized cones / medium VCs vajolet Multi-Way 14 3rd December 2007 06:10 PM
Aleph-2 50W@8ohm 20KHz emb51 Pass Labs 8 8th September 2006 04:10 PM
