Medium Aleph 3 8ohm@20w.
Old 2nd July 2018, 01:58 PM   #101
thimios is offline thimios  Greece
Originally Posted by tonimxp View Post
It is a dual mono clc filter, there are 16x22000uF of cap.
I don't believe that can be a psu problem.
Otherwise I don't need to decrease the gain but simply the input sensitivity.
Nice work!
Is the amplifier pcb for sharing?
Old 2nd July 2018, 02:06 PM   #102
tonimxp is offline tonimxp  Italy
Originally Posted by Extreme_Boky View Post
I see that you use star grounding. Check the pdf attached. It may give some guidance in that regard. There are also other clear explanations that could be useful.
Hi! Thanks for you advice, I will try to check as soon as.
Old 2nd July 2018, 02:10 PM   #103
Originally Posted by thimios View Post
Nice work!
I bought it on eBay.
Old 2nd July 2018, 02:35 PM   #104
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
I just discovered that if I do not use the unbalanced input and therefore do not short (-in) signal to the gnd , the noise is reduced considerably. Obviously, this can not happen if you use unbalanced input because it reduces the input sensitivity and even the low frequencies are poor.
In any case I would like to know if the capacitors of the PSU are efficient, how can I do it?
what?
when you're using SE inputs (RCA) , you need to short neg input to gnd
when you're using balanced , logically - neg input is not shorted to GND
in both cases gain is pretty similar/equal and there can't be any difference in frequency domain
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th July 2018, 07:16 PM   #105
Problem solved replaced 2x 4v7 (D1) with 1x9v1 low noise and now noise is nice!
Does someone try to adopt turbo in Aleph as F5 turbo?
Old 12th July 2018, 08:44 PM   #106
Zen Mod's Avatar
Wakootalian
what you mean with that ?
Old 12th July 2018, 09:09 PM   #107
Originally Posted by Zen Mod View Post
Wakootalian
After beer
However... I ask if is possible add turbo in Aleph.
Thanks Alex..
Old 12th July 2018, 09:56 PM   #108
Zen Mod's Avatar
I wouldn't try that
if you need bigger amp , just build bigger one
Medium Aleph 3 8ohm@20w.Hide this!Advertise here!
63watt class A into 8Ohm, 110watt semi-class A into 8Ohm, @ 20Khz 3rd harmonic -90dB FdW Solid State 47 31st December 2010 04:05 PM
8ohm resistor in series with 8ohm speakers for a 16ohm OT? Reidy- Tubes / Valves 8 10th January 2010 11:25 PM
Large Cone/large VC or several medium sized cones / medium VCs vajolet Multi-Way 14 3rd December 2007 06:10 PM
Aleph-2 50W@8ohm 20KHz emb51 Pass Labs 8 8th September 2006 04:10 PM
