I picked up an NS-10. It has a sticker on the cover stating a factor upgrade was done to an "e-series STASIS circuit design". The unit uses an auxilary power supply. I'm posting pictures of the PC board inside. It isn't that of an NS-10 and I'm unable to match it up with any other Threshold preamp PC board. There are no markings on the top of the board. I have not removed it to see if there is anything on the bottom.
Does this look familiar to anyone?
Thanks,
Eric M.
Update 2/19/18 Part number on underside of board 054-0023-NC
Thanks,
Eric M.
LOL! Yes it is. Mr. Pass had a sense of humor when assembling these
That's what I was thinking. But any similarity to a FET 10e ends there. The inside of the power supply matches that of a FET-10e I found online. I'm not sure if that helps at all.
Thanks, that time line matches up pretty well with when the last owner remembers sending it to Threshold for the update. I was hoping to track down a schimatic, but I'm guessing that's not going to be possible.
As I search, I've noticed there are about 7 or 8 versions of the FET 10e. I'm assuming these were design changes the factory did over time. Would you know if that is really the case? Did they really make that many changes over the years or are people just mislabeling schimatics and posting them on on-line?
Thanks,
Eric
Thanks,
Eric
That is a factory update that was pretty close to the Fet 10E. Later 1980's I think.
- Need help identifying Threshold preamp
