Hi all
I plan to use my ACA's to power my mid-hf horn's, these are super efficient so the power of the ACA will be ample.
As these only need to run from 500hz up ( set by the hi pass filter on the horn crossover) would there be any real advantage of changing the values around the input to form a Hi pass filter say 400hz?
Thanks for your thoughts.
Hello,
The French in the past did use 12 db filters at the input of the power amp and no filter at all between power amp and loudspeaker.
With horn loudspeakers you will have to use 12 db filter otherwise they will be damaged by receiving to much low frequencies. So in your situation just adding a cap, which is 6 db filter you will still need the filter between amp and loudspeaker.
Of course the amp will have an easier life if there are no low frequencies to amplify.
Greetings, Eduard
Greetings, Eduard
R11 is defining input impedance
Is it by purpose a relative small input impedance of 10k is chosen?
Would it be possible to raise to e.g. 47k?
I am using a passive preamp so would be good for me to have e.g. 47k instead of 10k. But 10k would also work I think.
So can we change the value of C3 to form this filter...
I have 2 of the new ACA kits on the way and the plan was to socket C3 so i could shrink its size to make a 1st order PLLXO to biamp the top of my WAW.
The less passive filter you can have, the better, i figure.
dave
dave
My thoughts exactly. I do like Zens idea to change the input and output caps to give a second order slope.
I did have a formula for working out the out cap value but can't find it. Tried the formula that Zen gave bit can't get his values, but them maths isn't my thing!
Might just trial and error it.
...and output caps to give a second order slope
In my case speaker is designed for 1st order filter and i don’t get the phase issues introduced by 2nd order filter.
dave
- Input filter on Amp Camp Amp
