I apologize, I guess my heading wasn’t worded very well.
I plan on building a pair of monoblocks, as close to the NP original 24 pair Anniversary edition as possible, maybe 3/4 build? Not sure if the 22 pairs I have will be enough that will match.
And to answer a few of the previous comments. Being lucky enough to come across these parts in the first place was a privilege, it would be ugly, in my opinion, to sell to the giving DIY Audio community at a premium.
No one could upstage what Walterw built! We was gutsy and brave to take on the task, in front of the diy audio community, as a first large scale build. And a beautiful finished product worthy of the Vfets.
I bought a bunch of parts to make something to measure the VGS. Maybe next week.
As long as someone saw value and enjoyment out of the transaction it's hardly ugly.And to answer a few of the previous comments. Being lucky enough to come across these parts in the first place was a privilege, it would be ugly, in my opinion, to sell to the giving DIY Audio community at a premium.
You could youtube stream throwing them one by one into a furnace too.
Unobtainium, what to do with them?
whatever that's your heart's wish ............ but post all the porn
I vote to send them to OPLDF.
If you want to sell me 2 pairs...
Ditto!!!!
Thanks everyone for your comments!
My “plan” would be to use 16 of the pairs, if I can get matching out of the extra 6 pairs, and or work trades to get to the 16. Anything left over I will sell to the members first requesting, at cost, if they are usefull.
I also have a couple PM’s that offer to help swap to help each other get matching pairs.
I hope to test and figure out where I’m at maybe next week.
I’m finishing up a speaker project, rebuilding my F5v3 turbo amps and really close to finishing up the Babelfish J monoblocks for my console project, before I start on this Sony project.
Plus I’m not an electronics guy, I have to find someone willing to help me figure out a schematic and design custom boards. I think I have a good design for the chassis.
I picked up another 4 pairs, so since I need to measure 52 pieces I thought I should build a proper test rig to save time and make it dummy proof for me.
I’m sure I have a mistake or two here, so I would appreciate comments before I fry anything.
I made it where I can bolt two on and then test one, then these the other, to save mounting and unmounting time.
I’m using Cleko’s for mounting. Faster than bolting and holds just as tight. If your unfamiliar they are usually used to hold sheet metal (automotive) together for welding or riveting.
I followed the test schematic but added a pair of switches to be able to make one rig and be able to switch between 2SJ28’s and 2SK82’s. In my simple mind it should work, but I’m not 100% sure.
I’m also unsure if the pin orientation is the same for both devices. I was only able to find the pinout for the 2SK82.
Ok , schmtcs are both OK , pinout is OK , look from bottom side , where pins are
GO!!!
edit : added some useful info ; not exact type , but case is and general info applicable
GO!!!
GO!!!
ZM, you about gave me a heart attack!
Thanks for replying.
Don’t worry, I know I’m not worthy to have these VFET’s anyway, so for sure do not want my ignorance to fry any.
So to testing, switch on battery power, then, with pot all the way counterclockwise, turn on power supply, then turn pot clockwise till I get .5v across 1ohm resistor?
- Unobtainium, what to do with them?
