Soz Psu
Hi all,
I m building a SOZ PSU. I m facing a kind a dilema (not that serious).
I have 800W/2*30V toroid transformers. Another part I already have is a bunch of 47000 uF/50V caps. If I go for a Pi filter, I'll end up with 43V rail which a bit to close (I guess) to the max rating of my caps.
I was therfore thinking to chokes. What about inductors (2mH) right after the rectifier. I d have 0.9*30 instead of the 1.4*30. It would lower my voltage.
Some questions now :
1. If I wind my own chokes, what diameter should I use ? #10 ? #12 ?
2. Is the efficency of the inductor regulation much lower when I put it after the rectifier instead of putting it in a Pi filter like described in Mr Pass Zen amps ?
Thanks for your help and thx to Mr Pass for shearing your knowledge with us.
Akira
Interresting, thx for the answer.
But this answers give me another question. Since I don t want to run a 30W SOZ (too expensive electricity bill) I could maybe use 7 volts to build the active supply regulation of Zen part 3.
This would give me a nice 35V rail for a 20W SOZ. The total dissipation of the amp stage would be around 500W instead of the 750W of a 30W SOZ (Pi capacitors resistors filter).
How much would be the power eaten by the regulated PSU ?
Do you think this would be a good solution ?
