"WHAMMY" Pass DIY headphone amp guide
Old 12th April 2018, 07:20 PM   #41
heijnsva is offline heijnsva  Netherlands
Definitely interesting and exciting project!
Old 13th April 2018, 01:24 AM   #42
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
The WHAMMY headphone amplifier PCBs are now available in the store:
Whammy Headphone Amp PCB – diyAudio Store
Old 13th April 2018, 04:56 AM   #43
mbedwani is offline mbedwani  Australia
Just ordered the PCB - \o/
Old 13th April 2018, 08:58 AM   #44
Mobes123 is offline Mobes123  Scotland
Hi Dennis,
thanks for pointing me to the gerbers!
cheers!
Old 13th April 2018, 08:58 PM   #45
HiGHFLYiN9s is offline HiGHFLYiN9s  United States
HiGHFLYiN9s's Avatar
Woot!
Any suggestions for a part # for the snubber? Looks like 22LS.
My DIY Electronics Blog: DIYAudioBlog.com
Old 15th April 2018, 11:29 AM   #46
ikek is offline ikek
I cannot seem to find the dimensions of the pcb either in this thread, in the "new PassDIY Heaphones" nor is it listed in the diyaudio store. Does anyone have the dimensions and are willing to share?
And last, how high does the stuffed amplifier board build in height in mm, will e.g. an enclosure with 40mm internal height be sufficient?
with regards,
ikek
Old 15th April 2018, 01:30 PM   #47
Dennis Hui is offline Dennis Hui  Canada
Hi Ikek,
I got my boards from Wayne last year (looks to be the same as the one in 6L6's
picture on page 1 of this thread) and they measure about 160mm x 218mm.
40mm clearance is pretty tight and you need to check your part heights. (The
total clearance of the Hammond case mentioned earlier is about 47mm.)
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 15th April 2018, 01:40 PM   #48
Thank you!
I am waiting on my board and was looking at enclosures. Easy to find a type I think I like but hard to know what would fit when dimensions are not, to my knowledge, easily available.
I found it puzzling that the dimensions are not mentioned at the diyaudio store page for this product.
with regards,
ikek
Old 16th April 2018, 07:31 PM   #49
After some digging I found one that looks good. LS is 22.5 vs 22 but should work. Mouser - 594-2222-336-10224 X1 rated.
6J6 I saw you used 35v Nichicon FGs for C3, C4, C9 and C28. Assuming 50V parts are for additional headroom/longevity but not mandatory? I'd like to try to shoehorn some Silmics in there. Also, what is the value of the orange capacitor referencing safety earth and signal ground. TIA!!
Old 16th April 2018, 07:34 PM   #50
6L6 is offline 6L6  United States
6L6's Avatar
I like the Nichicon caps mostly because they say "Audio Grade" on the datasheet -
I figure if some group of engineers much smarter than me is trying to keep the capacitor's response well-behaved in the AF range, then who am I to argue? Might as well use them. And they look cool.
Yes, the Lead spacing on the snubber is 22mm
"WHAMMY" Pass DIY headphone amp guideHide this!Advertise here!
FS: Nelson Pass "CSX1/2" "Buffered F6" Front End PCBs luvdunhill Swap Meet 7 10th December 2016 02:03 PM
Small midrange boost with conical "guide" suggestions? Phenoholic Anonymus Multi-Way 11 1st December 2014 12:00 PM
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
The "Dummies' Guide to getting parts/assembling CarlosFM's chipamp" Spasticteapot Chip Amps 19 18th March 2006 05:17 AM
