Replacement For Toshiba 2SK170/2SJ74
Old 13th June 2018, 07:40 PM   #161
WalterW is offline WalterW  Netherlands
Originally Posted by Itsmee View Post
Hi guyisme,
Thank you for the tip.
I was about to buy some JFETS from toshiba-san-1
Subtotal (20 pairs of 74/170): 257.62
Delivery to GB 263.99!!! that's a killer
OK, you'd expect to pay a premium for hard to find parts, but that's ridiculous.
I'd also have to pay customs duty on top of that!
Why is the shipping that expensive??? The weight is maybe 50 grams?
Punkydags the same...
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 13th June 2018, 08:59 PM   #162
JSA1971 is offline JSA1971  Canada
Originally Posted by drpro View Post
Check with "alweit" on ebay. He has been my source for several years now.
I just got my matched pairs from him. Super easy to deal with, and friendly. He’s also a member of this site.
Old 13th June 2018, 09:34 PM   #163
Itsmee is offline Itsmee  England
Itsmee's Avatar
I just got a reply from him, no discount on postage for for multi buy.
Thanks JAS1971, I'll try alweit; update - just bought 20 pairs, no BL, only GR and V, I'm happy with V
Old 14th June 2018, 05:26 AM   #164
darrr is offline darrr
I know that BL is the best but having the choice between the GR and V versions which one to choose?
Old 14th June 2018, 05:33 AM   #165
EUVL is offline EUVL  Europe
It is a wrong conception that BL is best or a must.
It really depends on the application.
If you are running the JFETs at a bias current below 6mA, e.g. in a diff pair, there is no difference between BL and GR.
If you want to use them to drive a low impedance load (<1k) as followers, then V grade is better.
So it all depends.
For many circuits like Aleph-JX, F5, F5X, F5-HA, ..... you can use GR grade without problems.
You just need to adjust some resistor values.
Patrick
xen-audio.com
Old 14th June 2018, 06:12 AM   #166
Itsmee's Avatar
Ditto Patrick, most of mine are for buffers.
Old 14th June 2018, 05:49 PM   #167
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
GR is fine for buffers. I have made quite a few with 2SK370 at 6ma.
If you use GR for F5 as example, the transconductance will be a little
lower, but that is compensated by the higher drain resistance required.
Old 14th June 2018, 05:53 PM   #168
Depends on what load and what max. output current you want to deliver.
If you can cherry pick 6mA Idss from GR then it is indeed not far from BL.
But then for buffer you can also use a pair of 2SK369V.
Patrick
xen-audio.com
Old 14th June 2018, 05:58 PM   #169
MASantos is offline MASantos  Portugal
I have some matched quads and pairs for sale in the swap meet area.
Old 22nd June 2018, 09:45 PM   #170
MEPER is offline MEPER  Denmark
Does anybody use the LSK and LSJ replacement versions and how good are they?
It seems most people still use the original Toshibas...…
Before I learned about the Idss stuff for FETs I got some LSK and LSJ grade A from the DIY store just to have some in stock for future builds. Hope I will be able to use them for something but it seems grade B and C are the versions which are used most.
Are grade A expensive because very few are falling in that category when they are manufactured? …..you don't manufacture for a specific grade...….you just manufacture and then the variation does that they fall into different grades?
Why did Toshiba stop production? …..they did not sell enough? ….as far as I can read the original purpose was for audio. Maybe they was made for low noise moving coil amps and when CDs took over the demand for these JFETs was not very high...…..or maybe because most young people are satisfied with MP3 music…...so real HiFi people is an "endangered species" that can't "eat" enough Toshiba JFETs......
Replacement For Toshiba 2SK170/2SJ74Hide this!Advertise here!
Toshiba 2SK170/2SJ74 FET's and other semis for sale duffears Vendor's Bazaar 63 6th December 2016 01:27 PM
Swapping matched for unmatched Toshiba 2SK170 / 2SJ74 Jfets NicMac Swap Meet 4 30th October 2016 06:16 PM
2SK170 2SJ74 F-5 BOM?????? paul stewart The diyAudio Store 5 19th July 2013 07:04 AM
FS 2sj74 and 2sk170's take 2 :) Woody1911a1 Swap Meet 43 28th August 2011 09:33 PM
2sk170, 2sj74 enzedone Parts 4 21st December 2008 05:38 AM
