Replacement For Toshiba 2SK170/2SJ74
Old 14th May 2018, 04:30 AM   #131
6L6 is offline 6L6  United States
6L6's Avatar
Correct. B&D sells a “pair” as one K170 and one J74 of the same grade. Not measured nor matched. Still, not a bad price.
I bought some K2013/J313 from them for a BA-3 project (no matching required) and it worked perfectly.
Old 14th May 2018, 01:15 PM   #132
toxic ingestion is offline toxic ingestion  United States
Oops. You are right. They always sold matching when I looked previously, but it is not mentioned now. I bought 50 of each some time ago and ended up with the great majority matching.
Old 18th May 2018, 08:45 PM   #133
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
First positive feedback about new seller of 2SJ74| 2SK170 jfet's are show on line today.
File Type: jpg 8C53F529-987C-4C17-ACF0-597F3032CFA5.JPG (325.2 KB, 831 views)
class A amplifiers with full range speakers
sings like angels in heaven
Old 23rd May 2018, 08:15 AM   #134
sarathssca is offline sarathssca  India
can low power MOSFETS like zvn3310 - zvp3310 be used at the input stage of preamps/amps in place of low power jFETs 2sk170 - 2sj74, in the complementary input stages like in BA-3 or in LTP input stages as in aleph series, BA-1/BA-2?
(may be cascoded to reduce the input capacitance in either cases)
Old 23rd May 2018, 11:27 PM   #135
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
As a concept, yes. However, other characteristics aside, these Jfets are
depletion mode, so they will conveniently bias themselves up without
external circuitry. The ZVN and ZVP have to be given either a bias
voltage at the Gates (relative to their Source pins) or biased by a
current source of some kind. In this sense, it is often simply a matter
of convenience to use the Jfets.
Old 24th May 2018, 02:51 PM   #136
Just checking at the option.. as here we have both n and p types of these low power mosfets available easily and at relatively lower cost.
So aside from biasing, how would they be when used in BA-3 (symmetric circuit) or LTPs (input stages) instead of the jFETs.
These MOSFET's input capacitance is higher when compared with jFETs , so do we need to go for adding cascode transistors to them?
Are there any other alternatives for depletion mode devices?
Old 24th May 2018, 05:31 PM   #137
The one and only
Cascoding is beside the point. Enhancement-mode devices, like virtually
all the Mosfet you might encounter, require some voltage between Gate
and Source pins before they will conduct current.
For an N channel Mosfet, that voltage would be positive relative to the
Source, and for a P channel Mosfet it would be negative relative to the
Source.
Depletion mode devices want to conduct current in the absence of
Gate to Source voltage. Think of a tube. For an N channel depletion
mode device, you have to apply negative voltage between the Gate
and Source to turn the current off, just as you would have to apply
negative voltage between the Grid and Cathode of a tube to shut it
off.
For an LTP, this would not be an issue, as generally they are biased
by a constant current source attached to the two Source pins of the LTP.
For a complementary input or follower circuit, you need to come up
with some DC bias voltage or current source to put the enhancement
mode parts into conduction. Depletion mode parts often don't need this.
Old 24th May 2018, 05:32 PM   #138
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
aleph reloaded thread
see and think
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th May 2018, 07:11 PM   #139
juanitox is offline juanitox  France
juanitox's Avatar
i have some 2SJ109 and a cheap component tester, if it say JFET device than it"s not a fake or is there other JFets with the same case available ?
French is not a crime.
Old 25th May 2018, 07:24 PM   #140
Zen Mod's Avatar
I'm not aware of ....... but one never know everything
Replacement For Toshiba 2SK170/2SJ74Hide this!Advertise here!
Toshiba 2SK170/2SJ74 FET's and other semis for sale duffears Vendor's Bazaar 63 6th December 2016 01:27 PM
Swapping matched for unmatched Toshiba 2SK170 / 2SJ74 Jfets NicMac Swap Meet 4 30th October 2016 06:16 PM
2SK170 2SJ74 F-5 BOM?????? paul stewart The diyAudio Store 5 19th July 2013 07:04 AM
FS 2sj74 and 2sk170's take 2 :) Woody1911a1 Swap Meet 43 28th August 2011 09:33 PM
2sk170, 2sj74 enzedone Parts 4 21st December 2008 05:38 AM
