Trouble shooting an F6 build
Trouble shooting is where my knowledge and expertise is lacking, I am more of a parts changer. I have been in the process of building and F6 and for the most part things have gone very well. A lot of that is due in part of 6l6s help.
The other day I went to wire up one channel, I had my VOM on the .47ohm resistor and was ready to adjust the bias. I turned the amp on and got no voltage across the resistor. I verified I had voltages going into the board and checked voltages around some of the resistors. I thought I had found a fried resistors but it turned out to be a false alarm. While I had the board out I noticed their was a hole in one of the keratherm pads I had installed. I am confident it was not there when it was installed it. Prior to installation I cleaned the heat sinks and check for burrs prior to installation.
Any help would be greatly appreciated.
-issue is what , exactly?
I get not voltage ratings across the bias resistor R2 on board B. I am afraid I have fried a MOSFET because of a hole in the keratherm pad.
which outputs , which exact schematic ?
I bought the boards from the diyaudio store and I have been following the build guide pretty thoroughly. The schematic can be found on the build guide done my 6l6.
care to post few detailed pictures ?
I can post photos later tonight when I get home.
Recommendation is 6.2v zeners with 3k3 resistors.
Like this.
