Aleph 5 100Hz problem
Old 6th April 2004, 08:59 PM   #11
piewie is offline piewie  Belgium
i still have got a slight humm when both amplifiers are switched on and connected to the same source. How could i best solve this.
No hum whatsoever with only one channel switched on.
Old 6th April 2004, 09:54 PM   #12
Holger Barske is offline Holger Barske  Germany
Holger Barske's Avatar
Sounds like a ground loop effect.
Both amps connected to the same wall mains outlet?
Best regards: Holger
www.holgerbarske.com
Old 6th April 2004, 10:07 PM   #13
both are indeed connected to the same outlet and are grounded.
It is indeed a grounding problem, question is how will i solve this.
I still have 4 VDR's laying around. Would it be wise to connect the supply gnd with these to the starground of the monoblocks.
Specifications
* operating voltage:
o Vac: 50V
o Vdc: 65V
* type: S20K
* dimensions:
o D: 22.5mm
o T: 4.5 .. 5.3mm
o d: 1.0mm
* pitch:
o e: 10mm
* response time: < 25ns (< 10ns with SMD varistors)
* electric strength: 2.5kV
* insulation resistance: > 1Gohm
Old 7th April 2004, 12:51 PM   #14
Solved the problem with inserting a 5W 100ohm resistor between star ground and ac gnd connection of one monoblock. Now the ground loop has disappeared.
picture of finished project.
I'll anodise them later
Old 7th April 2004, 01:43 PM   #15
Alain Dupont is offline Alain Dupont  France
Alain Dupont's Avatar
piewie,
Great job, nice pair...
Alain.
Aleph 5 100Hz problemHide this!Advertise here!
Using SS to augment < 100Hz? bigwill Tubes / Valves 3 25th January 2009 05:13 PM
Which Driver to use for 100hz-500hz? KCCT82 Multi-Way 27 6th January 2008 03:59 PM
How to kill a 100Hz open baffle resonance? Katapum Full Range 12 22nd November 2005 03:51 PM
subwoofer/woofer to go up to 80-100hz? Guijs Subwoofers 2 24th October 2005 08:23 PM
question on rolloff below 100Hz wintermute Chip Amps 4 16th December 2003 03:23 AM
