Different enough. The DP is a depletion mode part which typically has
Vgs voltage at -3 to -5V, and the EP is enhancement mode at about +1 to
+2V.
After that, they are somewhat similar.
The DEF amps discussed elsewhere in this forum used the R085's for the
depletion mode device.
+2V.
What springs to mind is a Zen type amp with R100A underneath a R085 top load .
Maybe R100 follower with R085 self biased current source,
or
R100 operated Common Source mode like in J2 with R085 on the top as
mu follower.
with pair of SJEP , say Aleph Jango (Aleph J iteration , one of Most Greedy Boyz made by Papa's hints)
mu follower.
That's the sort of thing I was thinking of . For this project I intend to only purchase the heatsinks and output capacitors and really splurge out using some of the parts from 'the mountain' .
It will be built on a piece of wood and be a perpetual prototype so almost anything goes I have 97dB sensitive speakers (15"+TPL150H) so only need a clean watt .
The J2 thread is a beast . Is there a go-to post that has a schematic or can you share something ?
What about the Amp Camp Amp with Semisouth devices top and bottom ?
Thanks to all who responded
316a
I was going to say use the R100 in an ACA, adjust for lower Vgs of the R100 as some have done previously with a 1 pair aleph mini (you can search DIYA, member "teabag" even made an article), except with ACA mu follower as irfp240.. and maybe use the 085 for something else.. (obviously that DEF amp).
J2 is outa combination , needing pair of SJEP per channel
Would this one work? (Digikey)
Cree C3M0120090D
Silicon Carbide Power MOSFET
C3M
TM
MOSFET Technology
N-Channel Enhancement Mode
yup , all of them to same value
(general remark for number of big resistors - if one pair of outputs , then two parallel in output node....if two pairs of outputs , then four parallel ones in output node)
say 0R33 is safe bet , while 0R22 is for fearless Papa Followers
(seriously now - nothing to fear from)
Cree C3M0120090D
C3M
TM
MOSFET Technology
dunno - didn't tried and frankly - lost count of tried substitutions , here on forum
maybe because I wasn't personally interested in finding substitute for Semisouths
- Project for Semisouth R100A and 085
