Citation 12 non-complimentary to drive ribbon tweeter
Old 3rd January 2018, 01:19 AM   #51
woofertester is offline woofertester  United States
Originally Posted by PRR View Post
I wonder if 300 Amp peaks will rattle your door-knobs with the radiated field.
Ribbon microphones need careful design of the return path; using "enormous" wire. Also bringing a wire back down both sides of the ribbon to cancel external fields.
Steady current of 300A wants US#00 Copper wire 0.365" diameter. Which is not a common wire- we use Aluminum in such sizes. For this and other reasons your return path is more likely many wires. (Or bar-stock, but it has no conductivity rating and some minor impurities really hurt that.)
Since your average current is well under 30A, #12 wire won't burn, but has too much resistance.
I had thought the amplifier obviously must be ON the loudspeaker. Well, no. Take ten #6 Copper wires 10 feet long, 0.4r per 1,000 feet. It will be below a milliOhm. So the amp can be in the base.
With a complement P-type, and some clever copper-work, I would be confident of delivering 9V at 300A to a 0.030 Ohm load. I *really* would go massively parallel. Not just because your devices are rated 200A lead-limit, but because the connections and reservoir caps need to be massively parallel so the parasitic resistances do not add-up so fast.
If a 8-Ohm amp takes two 10,000uFd caps, then a 0.03r amp takes two 2,666,000uFd (3F!) caps. DigiKey lists 15 caps 1F+, and will sell you a few 1F@25V for $80, but only 15 in stock (24 week lead-time). A bipolar stereo set is 8 or 12. A kiloBuck. Not prohibitive. ESR 5mOhms each, OK. Ripple current 40A, so it won't do 300A as a welder, but fine for speech/music.
The Gate capacitances are on the order of several nanoFarads, even as a Source Follower. Penciling 10nF, that's around 1K Ohms at 16KHz, 100r at 160KHz (where you need controlled gain for NFB stability). OK, that's actually in the zone of some $1 chips.
One thing-- unlike the vacuum forum, here you have almost no fear of shock (after you button the line wiring). You do have a VERY dangerous machine nevertheless. Get your wedding ring across those caps and it will burn through your finger then vapor-deposit Gold all over the room. Arc-blindness is possible. The repulsion of 300A peaks can tear-apart large transformers, or your cap-buses. Every high-current conductor will shake with the beat.
I understand your goal. But this is new territory. I would *really* think to use a transformer to run the speaker. Monitor the actual current/voltage demand for good level, or estimate the additional juice needed to reach a good level. Just finding that 150A is ample saves ~~3/4 the stuff.
Transformer appears to be a large core with an 8 Ohm winding (any primary, N/C) and 3 to 5 turns of the fattest wire you can slip around the coil-build without scraping on the iron. If there is space left, wind bi-filar, and work parallel for less loss.
Thank you for making technical points about the original topic. This sort of reply is what I have been waiting for since my original post. Many of your points are exactly what I have been thinking.
The high current stuff should happen after the 1F capacitors. The transformer should not see the hundreds of amps unless it is kickback/flyback.
Copper bar stock for connecting drain and source of output FETs. Probably have to learn how to gold plate over nickel plate over the copper bar stock or send out the bar stock pieces to a professional gold plate house.
1F +/- of capacitance connected across the above bar stock across every power FET. The super capacitors may not have low enough ESR. Will have to experiment for selection of capacitors to live on top of the power FETs.
Understood about the safety concerns. It might be fun to hang a conductive mobile nearby to see it dance with the music. Or a rack of wind chimes.
Massively parallel is how the commercial amp solves the problem. I believe they use 10 pairs of 50A transistors.
For the proof of concept, one pair should suffice to take measurements to help calculate full-scale implementation.
I would like to have a workable transformer design to satisfy those people who are willing to live with the transformer artifacts.
Nice inputs!
Old 23rd February 2018, 04:13 PM   #52
Simplex2 is offline Simplex2  France
Hello folks !
All yours assumptions are based on the dB/m/W estimation . You compare an honorable 1/2 inch Audax with a half space spherical wave with a 1/2 inch and 10inchs long ribbon tweeter with a more directive cylindrical wave , that's not the same distance attenuation . You can at normal listening distance add a good 10dB . Musical signal is poor over 3kHz and power requirement are 6 to 10dB Lower . Real world listening is in the 70/90 dBA range and that's rarely more that 10W peak with classical loudspeaker .
All in all you don't need to flash your tweeter with 500 amps . Think , most of the power will be wasted in thermal energy , can your aluminum foil ... yes it is not a toaster .
Your first assumption with 20V 40A is quite good looking , the foil dissipate at the max 800W quite hot enough . Power requirement stay in the high side but are more realist .
You possibly need less , but the solutions are on the acoustic side .
Limit the acoustic shortcut , the use of a wave guide or horn , a longer ribbon ...all that was explored .
Simplex2
Old 24th February 2018, 11:33 AM   #53
woody is offline woody
One other little problem might be the input capacitence of that output mosfet. At 44,000 Pf the original circuite just won't drive it. As was said earlier it would be cheaper to just spend some money on a good magnetic structure .
Old 24th February 2018, 12:11 PM   #54
Understood. If maximizing ribbon sensitivity were my goal, I would have aired this in the exotic speakers forum. I am happy with the ribbon as-is. It is the result of multiple generations of design. The ribbon is simplified for construction, cost and repair.
I posted here because this is the forum of amplifier excess and I was looking for an excessive amplifier solution.
I agree about the capacitance. Measuring the capacitance curves is on the list of things to do sooner than later.
Old 24th February 2018, 05:37 PM   #55
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I think this is one of those deals where you want to build some circuits up
and see how it goes. Otherwise it's easy to over-think it.
Maybe you will need more drive current for the Fets, maybe not.
Old 24th February 2018, 05:42 PM   #56
Advice taken. Will do. And and always, thank you for the advice.
Citation 12 non-complimentary to drive ribbon tweeterHide this!Advertise here!
Citation 12 complimentary Mosfet version PCB's Tazzz Swap Meet 50 Yesterday 10:19 AM
ACR RP400 Isostatic tweeter (Fostex FT7RP) Exchange to a Visaton MHT12 ribbon tweeter BMW850 Multi-Way 9 27th March 2016 10:59 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
how can i drive a complimentary symmetry output stage SVI2004A Solid State 11 9th January 2009 10:18 AM
hk citation twelve stock or mosfet version to drive original quad esl's ? vaslejean Solid State 2 11th March 2007 11:15 PM
