Citation 12 non-complimentary to drive ribbon tweeter
Old 28th December 2017, 03:36 AM   #11
woofertester is offline woofertester  United States
That particular gap is intended for a wider diaphragm. A narrower gap will increase sensitivity, but not enough to negate the need for a massive amount of current to keep up with any normal cone speaker.
Opposing flat magnets cause a sharp suckout at a frequency inversly proportional to the distance between the magnets. A more narrow gap pushes the suckout frequency higher. The Magnepan IIIC tweeter has a deep suckout at 9 kHz. The ribbon is narow and the magnet gap is narrow compared to the tweeter pictured above.
Using stronger magnets makes assembly more difficult and actually dangerous. The magnets want to collapse on to each other in the gap pinching a finger quite easily.
Old 28th December 2017, 05:58 PM   #12
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally Posted by woofertester View Post
So, the ribbon is no better than 60 dB @1w @1m.
There is something wrong here. 3 mA is about .00007 watts through 8 ohms.
Old 28th December 2017, 11:08 PM   #13
The sensitivity of the midrange was calculated from the T/S parameters. It just happens that the SPL meter measured very near the dB sensitivity at 3mA with the SPL meter very near the midrange dust cap.
The tweeter is so quiet that the SPL meter does not deflect on the lowest range. I have to get an amp involved so that I can drive the tweeter enough to get a measurement.
Then, ... I will have to calculate the power into each driver and correct for the disparate powers.
I will post better info when I have it.
Old 29th December 2017, 12:33 AM   #14
Better info is below
3kHz signal. Near field measurements on on both drivers. Current through driver is set for 85 db near field for each driver
The ribbon diaphragm is about 0.5 ohm
The midrange is about 12 ohms at 3kHz
Ribbon 85 dB at 1.3A, 850 mW
Midrange 85 dB at 32mA, 12 mW
The tweeter requires 850 / 12 = 69X more power, 18 dB less sensitive
Let me know if I made a miscalculation somewhere. I used the 2 most significant digits of the current measurements and rounded subsequent calculations to two significant digits.
Old 29th December 2017, 12:43 AM   #15
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Additionally can you put 2.818Vrms through each driver and record the dB value on your meter.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 29th December 2017, 10:58 AM   #16
The drivers would not be at equal input power at 2.82 vrms and you would have different SPL readings. You would have to calculate the power ratio , convert to dB and then add dBs to one of the drivers and then subtract the two.
The way I did it seems simpler to me.
Old 29th December 2017, 03:22 PM   #17
The one and only
OK, so let's say you have 86 dB at 1 watt at .5 ohms, which is 1.4A:
( 1 W = I^2 * .5 ohms )
106 dB at 100 watts, 14A
120 dB at 2,500 watts, 70 amps (100a peak)
Correct me if my math is wrong....
Old 29th December 2017, 05:54 PM   #18
Your math is excellent. Two things
1. My measurements were very near field, about 1 inch from the driver. At a listening position, the dBs will be lower. The 86 dB sensitive midrange only required 12 mW to achieve 85 dB right at the cone. 10*Log (1/0.012) = 19 dB. So, as a wet thumb in the air, subtract 19 dB from your numbers.
2. The ribbon measured is 1/2 inch wide. The skinny ribbon is more than 10X lower impedance.
Old 29th December 2017, 11:41 PM   #19
I would be taking more measurements depending on how good that dB meter is.
At least 3 different points.
Old 30th December 2017, 12:14 AM   #20
The dB meter is a vintage Radio Shack analog hand-held unit. I performed the measurements more than once.
3kHz is in the passband of both the tweeter and the midrange.
At this point, I am satisfied that the ribbon will require much more than 100A peaks. It makes sense to have peak current capability of 300 to 400 amps.
Citation 12 non-complimentary to drive ribbon tweeterHide this!Advertise here!
Citation 12 complimentary Mosfet version PCB's Tazzz Swap Meet 50 21st July 2018 10:19 AM
ACR RP400 Isostatic tweeter (Fostex FT7RP) Exchange to a Visaton MHT12 ribbon tweeter BMW850 Multi-Way 9 27th March 2016 10:59 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
how can i drive a complimentary symmetry output stage SVI2004A Solid State 11 9th January 2009 10:18 AM
hk citation twelve stock or mosfet version to drive original quad esl's ? vaslejean Solid State 2 11th March 2007 11:15 PM
