Pearl Phono Problem -- Need Help!!!
Old 4th April 2004, 07:46 PM   #1
Mikelo is offline Mikelo  Antarctica
Default Pearl Phono Problem -- Need Help!!!
I built the external power supply with about 40VDC output as suggested in the manual, and that's what I measure in both channels when they are not hooked-up.
But when I hook-up the outputs to the phono boards, I measure only 8VDC, and this on both boards!
If I connect only one channel, I get a higher reading (9.2VDC) and strangely enough the other unconnected channel has an output of 10.1VDC at the external ps output.
I have connected the ps and signal grounds per the old instructions. The signal inputs and outputs are still unconnected.
I hope someone will be able to help
Old 4th April 2004, 08:35 PM   #2
ingvar ahlberg is offline ingvar ahlberg  Sweden
ingvar ahlberg's Avatar
Hi
Seems like current limiting, are You shure everything in the psu is connected right? As it shows on both supply channels even thoug only one is loaded it must relate to something that is common for both. Transformer ofcourse but seems to big a drop for beeing that.
Could You draw Your psu up exactly as it is and post?
Ingvar
Old 4th April 2004, 09:38 PM   #3
Thank you very much for pointing me into the right direction, (namely to my stupidity).
I filtered the AC line with 4.7K resistors instead of the 4.7 that
are called for. That would limit current.
Michael
Pearl Phono Problem -- Need Help!!!Hide this!Advertise here!
PCB for Pearl Phono Pre sonix Pass Labs 2 4th March 2006 11:41 PM
Pearl Phono Done (almost) Gregorio Pass Labs 0 16th January 2006 01:42 PM
Problem with hum/buzz in Pearl Phono Buhl Pass Labs 11 10th June 2005 11:03 AM
Pearl Phono PCBs Weil Pass Labs 9 22nd May 2005 10:40 AM
pearl phono hsort Pass Labs 5 2nd March 2002 09:26 PM
Copyright ©1999-2017 diyAudio
