Questions about amp camp amp and linear power supply
Old 5th February 2018, 11:50 AM   #21
Those high measurement values must be at the PSU.
It would help you and us a lot to also see the measurement values at the speaker output terminals. With the inputs shorted and with the source connected.
regards Andrew T.
Old 9th February 2018, 07:03 PM   #22
kking85743 is offline kking85743
Sorry, should have specified: the measurements were taken at the power supply with the amp on, no input (pre-amp off) and speakers plugged in. As close to nominal use case as possible. Also, Amp was warmed up.
I will check what it looks like at the speaker's early next week.
Old 17th February 2018, 08:37 PM   #23
Ok, the data is pretty simple. Almost no variance between sides, or between inputs (present w/ preamp off, shorted, open), and almost no difference with or without speakers plugged in. I am also including self-noise values for the cheap USB scope (probe attached, but not shorted) for comparison:
Questions about amp camp amp and linear power supply-capture-png
My guess is that this is beyond good enough (15mV peak to peak above self-noise, and no RMS difference over self-noise), and that I should put my effort into building speakers rather than building a Power Supply filter. Or saving for a better scope...
Questions about amp camp amp and linear power supplyHide this!Advertise here!
Linear power supply Jolida Power Supplies 7 13th October 2016 08:10 AM
Linear Power Supply for Amp Camp Boards (Question) Jennifer G Pass Labs 18 7th June 2016 05:44 PM
Camp Amp and power supply stenak Pass Labs 5 7th April 2016 10:01 PM
Power One 5v 3A linear power supply SilverStrings Swap Meet 0 23rd September 2010 07:06 AM
Power One 12V 10A linear power supply boywonder Swap Meet 0 11th September 2010 04:38 PM
