Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans
Old 16th April 2018, 11:58 AM   #281
First Watt Guy is offline First Watt Guy  Viet Nam
Originally Posted by Zen Mod View Post
I made sim with SJDP
tonight with SJEP , OK ?
Thanks , sir
But how can I search for SJEP with the same vgs as IRFP ?
Old 16th April 2018, 02:41 PM   #282
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
you need SJDP if you want to pair it directly , without additional bias circuit , and I can't tell you is that even possible , because I didn't make any analysis regarding biasing voltages at desired current
make distinction between enhancement devices (SJEP , IRFP) and depletion devices (SJDP , JFets) ......... then you'll understand why you need SJDP for possible direct pairing with IRFP
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th April 2018, 05:51 PM   #283
Zen Mod's Avatar
Default as promised - SJEP , so no DEF but EEF
Old 16th April 2018, 07:35 PM   #284
Samuel Jayaraj is offline Samuel Jayaraj  India
SEF
this one goes in prototype
Zen Mod, I experimented with your SEF circuit. I left R7 at 220E as in original M2. R1 & R2 was made by a string of 0.18E X 3, 5watt each. But they got too hot in just a few minutes.
I couldn't get offset below 4 volts. Hence, used a 4700uF cap to connect the speaker.
Sound was fuller, more organic, forward and airy. But the liquid character of M2 was sacrificed.
Comments.
Sam
Old 16th April 2018, 07:37 PM   #285
The SEF circuit is in post #264.
Sam
Old 16th April 2018, 08:10 PM   #286
Zen Mod's Avatar
any of these amps made with DEFiSIT as role model , will have greater THD than M2 , so it is logical to sound less clean , erring on sweet side
regarding values in any of shown sim schematics , they're exactly that - simulations , so some value tweaking in vivo is inevitable
setting correct Iq ( look at Pd per device - 35 to 40W) and offset is trivial thing , done in 20min or so
so , fear no more but no less , you'll need to wait for (slow) Mighty Moi , to show in vivo values , in case that you can't fix them by your self
Old 17th April 2018, 03:21 AM   #287
Thank you Zen Mod for your response. I could try setting offset etc. What is the dissipation in R1, R2 & what wattage would be appropriate? Thanks.
Sam
Old 17th April 2018, 08:33 AM   #288
Zen Mod's Avatar
everything is on schematic
top of R1 is 1.01V , bottom of R2 is 3.8mV
so , I=U/R
1.01/(2x0R27)= 1A87
dissipation in resistor P=I^2 x R
P=1A87^2 x 0R27=940mW
3W resistor will do
so , you need to have one voltmeter across any of 0R27 to observe and set Iq , and second voltmeter across output to observe and set offset
write here what your results are and I can tell more precise what to do
Old 17th April 2018, 03:21 PM   #289
I didn't bother to change R7, and it remains at 220E.
My R1, R2 combination is 0.54E. Voltage drop across this resistor is 1.26 volts. To be sure, I put an Ammeter in the positive supply line and measured a current draw of 2.36 Amps.
Sam
Old 17th April 2018, 05:34 PM   #290
Zen Mod's Avatar
well , bother
('till you get 1V across 0R54)
Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's KoansHide this!Advertise here!
PAPA'S KOAN ....... was Papa's Surprise Zen Mod Pass Labs 41 18th August 2012 06:48 PM
to all greedy boyz Zen Mod Pass Labs 44 24th June 2007 11:15 PM
greedy boyz ............again Zen Mod Pass Labs 30 14th June 2007 03:03 PM
