And them THFs will stay in Opldf a good while for advance tune up session.... there was a purchase of 12 pcs of THF-51S and two pairs of CMOQ4-LPC
I believe I'll squeeze them in (last) schmtc with 2SK180 , already posted here in thread ;
that will go on upcoming SEF/Babelfish M2 pcbs
two criteria are fulfilled :
- it is SIT , so fast as Sparrow's fart
- with that schematic , current distribution between parts is same Wakooo as in Papa's DEFiSIT - mosfet doing all the work , while SIT acting as error correction , or whatever correction ......... maybe Wakoo Correction
only jumping in to help when mosfet is outa breath
Tnx
Will finish measurements on Monday ;
as I said , need more oomph for amp input , to move it to full power ....... EMU1212 is not having enough swing as is
then will open separate thread , post latest schematic and call it done
then on to SEF amp , as soon I receive pcbs ........
just from habit - my fave Philips 1uF MKC , as bypass on C1 and C2 position
did I wrote that Papa sent all caps in bubblie ?
....... more precisely - all parts , except small metal films
I also changed C2 to (also) my fave (125C , so industrial?) ELNA 470uF/35V
Just bought some of the Philips 1uF MKC devices, but only found yellow axial versions. where can I locate those blue ones?
Russellc
with present state of 2 cells (multitasking in several planes, besides just finished late lunch , so cells starved more than usual) , I should say - why not
be careful how to manage these two voltage sources , noiseless is a must
observe F6 for few tricks , combined with M2 and DEFiSIT , of course
few clever tricks also buried in Antoinel's threads
Sorry I typed with a tablet, almost asleep making typo.
I think the circuit can make a sound anyhow.. But is this the DEFiSIT, with those advantages that Nelson described?
1. Single-ended sound with such harmonics
2. Doubled output due to push-pull
3. Increased damping
Cheers
Cheers
well , it could be kind of "rearranging of standard" , as in Jazz music .....
however , without spending some time with simulations , I can't predict exact behavior of these wakoo combinations
if you go back , you'll see graphs I took from simulations , showing insane current distribution between active parts - up to the clipping , mosfet (lower part) is doing extra heavy work , while SIT is actually working against the mosfet ...... as sort of ( who knows , is it?) naturally born phenomena - error correction or what ....... anti-error correction
anyway , with xformers involved , where gates aren't tied tightly as in DEFiSIT , I believe we will not have that sort of current distribution ......
so , I can't promise when I'm going to make that sim for you , being pretty ocupied with daily work and soon to have SEF/Babelfish M2 zero gen pcbs , on which I hope to implement also THF51-S beasties ........
maybe after that ......
homework #1
per tips from mighty uncle ZM.
Stolen legos from F6, Sony VFet part 1, Nelson's DEFiSIT....
Before I do dumb things with my tower, let me hear from you what can be wrong.
Looking at F6 it seems Schade feedback seems possible, but it's beyond my head.(Opto coupler too)
But I once tried Schade feedback (know to me as partial feedback then) even to 300B triode and I remember it was good.
You are not promising but you don't have to. I appreciate it enough!!
I have this Dual PSU 30V 3A CC CV and I think this is safe tool to try the circuit.
Cheers
- Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans
