Can I build one?
Can I build one?
Old 6th November 2017, 06:12 PM   #1
damkel is offline damkel  Denmark
Default Can I build one?
Hi
I love to build things, and I am not a complete beginner when working with either wood or metal.
But I have never build an amplifier or something like that.
I can solder - so far so good.
But, can I build one of these Pass Labs amplifiers, maybe phone amplifier.
Can I as an absolute beginner build something like that?
If I follow a build guide but without really knowing what I am doing will I get something that works and work well?
Also, what will I need of tools?
I got solder station, and a multimeter (and a lot of what I will can normal/basic tools) but what else will I need?
And a bonus question :-)
How is the best way to get basic knowledge about amplifiers etc.?
I hope this is not stupid questions but as funny as it is to make something well it is even better when it works :-)
Old 6th November 2017, 06:46 PM   #2
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Well well it's almost as if Nelson was thinking of you when he came up with this Amp Camp Amp Kit – diyAudio Store
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 6th November 2017, 08:36 PM   #3
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Can I build one? Send a message via Yahoo to vdi_nenna
Don't rush your project.
Measure each resistor and check it's wattage before soldering on to the board.
Check all parts that have polarity: diodes, electrolytic capacitors and semiconductors and make sure you are installing them in the correct orientation on the boards.
Install small parts first: resistors, diodes, caps and semiconductors last.
Leave a space under higher wattage resistors so they can get air around them.
With semiconductors, as well as other parts, download the spec sheets and study the part's leads and what they are named. Find corresponding positions on the board.
Think about, meditate and obsess over what you will do next before you do it.
I build, therefore I am.
Old 6th November 2017, 08:40 PM   #4
vdi_nenna's Avatar
Originally Posted by damkel View Post
Hi
Not a stupid question. Read the Zen articles on passdiy.com. Start with Zen amp version 1.
Watch videos on youtub.com on how amplifiers works. They focus on mosfets amps around here, so look for mosfets class A amps.
Old 6th November 2017, 09:07 PM   #5
PRR is online now PRR  United States
PRR's Avatar
....without really knowing what I am doing will I get something that works and work well?...
A friend worked at an electronics factory, soldering cans and crunchy-caps by rote. NO understanding of electronics. Only a dim understanding what the product was. It happens I had one of those UHF converters and it worked fine.
At Fender, Fisher, and essentially all audio factories, 99.44% of the work is done by women with fine finger skills and no electronics training. The work is transitioning to robots, which maybe "are" electronic, but do not "know" electronics.
Knowing what you are doing may be a bonus, or may get in the way. I see people who start throwing-in "improvements" with only partial understanding, and this sometimes goes wrong. I try to put my deep theory to the back of my mind and wire blindly according to the layout I have worked out or found.
Old 6th November 2017, 09:10 PM   #6
aspringv is offline aspringv  Australia
Can I build one?
Default answer in detail
Ok, full answers!
Absolutely - there's heaps of options, so spell out a goal and budget and the community here will give you a hand.
Yes! And if it doesn't work then the folks here will help you out debugging it, and you'll learn heaps about how it should have worked
a set of side cutters? I think you'll be fine.
Read and build. I'd start with the articles on FIRST WATT ARTICLES and work your way through them, or start with the f5 article and there's a pretty solid grounding.
I made a chipamp first (it was really simple to do and still works great today, and was reasonably cheap to do) and then graduated up to the big power supply, big metal, class A builds here in pass labs land.
Fair! But if it doesn't work, you'll learn even more, and the worst that can happe is you're left with a chassis and a transformer for the next project
Old 6th November 2017, 10:34 PM   #7
wayne is offline wayne  United States
Auburn
wayne's Avatar
Can I build one?
a soldering iron and voltmeter is enough to build the headphone amp. It has no adjustments and works just fine if you use the indicated parts.
wizards assistant
Old 6th November 2017, 11:00 PM   #8
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Headphone amp, or ACA is a good first project
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 6th November 2017, 11:09 PM   #9
AudioSan is offline AudioSan  Norway
Aleph mini Aleph J or Aleph 3 can also be a good place to start. Or maybe a standar F5.
Old 7th November 2017, 06:14 PM   #10
Thank you everybody for your nice replies.
Seems like I will have to choose what to build and get started!
To bad the Amp Camp Amp kit is sold out - seems like a good place to start and get some basic skills.
I think I will try and find the parts myself and make it anyway - properly a good idea anyway then I can find places to buy the parts :-)
Can I build one?Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
question:How to build How to build music player with tda1543 use rapspberry pi B+? gary095315 Digital Source 1 30th December 2015 07:35 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
