Can I build one?
Can I build one?
Old 7th November 2017, 07:08 PM   #11
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Good luck and have fun, you have the right attitude
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 7th November 2017, 07:12 PM   #12
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Can I build one? Send a message via Yahoo to vdi_nenna
ACA is a great amp and project. I'm amazed by it every time I switch it on to listen to it.
I build, therefore I am.
Old 7th November 2017, 11:39 PM   #13
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Can I build one?
ACA 1.1 is coming out (it'll be at BAF) and it's a two channel piece that is
less expensive yet.
Old 7th November 2017, 11:58 PM   #14
vdi_nenna's Avatar
Does the 1.1 use laptop power supplies?
Old 8th November 2017, 01:50 AM   #15
KevinHeem is offline KevinHeem  United States
KevinHeem's Avatar
Can I build one?
My first project ever was one channel of the zen amplifier built point to point on perf board. It was powered by a lab DC power supply with an iPod as input and a cheesy little speaker connected. Hearing music from something I had actually built was exhilarating! On a very small scale I was able to experience each step in the process of amp building. If you're starting a journey as a hobbyist I would suggest you start there or someplace similar.
And yes, YOU can absolutely build an amp!
Old 8th November 2017, 06:35 AM   #16
JPS64 is offline JPS64  Germany
Can I build one?
Still available in my first GB, ACA PCB: part list attached.
Very busy, no progress on mechanical side!
JP
Old 8th November 2017, 06:58 AM   #17
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Nice one.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 8th November 2017, 07:30 AM   #18
Can I build one?
Thank you @2 picoDumbs
Donīt forget, Iīve still pair F6 + supply for free for you (need postage address).
JP
Old 8th November 2017, 08:50 AM   #19
damkel is online now damkel  Denmark
JP
Forgive the noob - but I'm not sure I get the meaning of this post?
Old 8th November 2017, 04:22 PM   #20
The one and only
Can I build one?
Yes, 19V or 24V.
Can I build one?Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
question:How to build How to build music player with tda1543 use rapspberry pi B+? gary095315 Digital Source 1 30th December 2015 07:35 AM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
