Direct Coupled B-1 Buffer - Hypnotize troubleshooting
Old 5th November 2017, 03:55 PM   #1
Pboden is offline Pboden  Norway
Default Direct Coupled B-1 Buffer - Hypnotize troubleshooting
Been away from diy audio for years and yesterday I ran through some old stuff in the attic and found an old project that never was finished - among the B1 Buffer.
I started up the B1 buffer today, but I can not get it running - that is no music.
I see that there are some leds that do not start.
Appreciate any help on troubleshooting.
File Type: jpg IMG_20171105_172502_resized_20171105_053039937.jpg (264.9 KB, 217 views)
Old 6th November 2017, 04:47 AM   #2
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
Looks like the V+ side of the regulator doesn't turn on. I'm saying that because the 5 LEDs stay dark. Check part orientation and solder joints.
Gravity - Making the G since 13.7 billion B.C.
Old 6th November 2017, 12:28 PM   #3
R.I.P.
if you are really careful you can measure the voltage across each LED.
You may find that one has a very high voltage indicating it has been inserted in reverse.
Can you see the flat edge indicating the -VE side of the pair of lead outs?
All the good ones should have around 1.7Vdc to 1.8Vdc across them. That is the Vf when current is passing.
regards Andrew T.
Old 6th November 2017, 01:46 PM   #4
Well I just removed the leds on the "faulty" side and there are no voltage on the pcb.
Where/what is the source for those five leds ?
Old 6th November 2017, 06:25 PM   #5
R.I.P.
do you still have the schematic?
regards Andrew T.
Old 6th November 2017, 06:40 PM   #6
Yes, found it - Mezmerize B1 Buffer – diyAudio Store
Trying to locate the possible culprit so I believe I have to start messure somewhere, so any tips would be appreciated.
Old 6th November 2017, 07:30 PM   #7
R.I.P.
start at the AC input.
Then move to the rectifier in and out.
regards Andrew T.
Old 6th November 2017, 08:27 PM   #8
I get no voltage on one of the irf9240. Around 6Vdc on the other.
Just made a order for new ones.
Old 12th November 2017, 07:54 PM   #9
What is actually accepted AC input (range) on the board ? My previous problem may be due to a faulty transformer.
Old 13th November 2017, 06:55 AM   #10
R.I.P.
The DCB1 needs at least 5V and preferably 7V across the CCS part of the regulator.
This is required when the mains voltage is at it's lowest.
You can use a dual 15Vac secondary wired as a centre tapped secondary and in normal operation you will measure 20Vdc to 22Vdc on the main smoothing capacitors.
regards Andrew T.
Direct Coupled B-1 Buffer - Hypnotize troubleshootingHide this!Advertise here!
FS: Direct Coupled Pass B1-Buffer - Hypnotize Version Rudi_Ratlos Swap Meet 3 16th August 2017 02:37 PM
How to diy wyred sound direct coupled dual balance fet input buffer? mbl Class D 3 24th May 2015 12:28 PM
FS: Hypnotize B1 Buffer Sergelisses Swap Meet 3 25th June 2014 01:22 PM
capacitor coupled vs. direct coupled ouput hugobross Solid State 11 21st January 2011 01:56 AM
6sn7 direct coupled and transformer coupled neazoi Tubes / Valves 3 23rd May 2008 03:30 PM
