I am concidering building a Zen amplifier. It seems simple to start a version 1 and the upgrade along the way until 7 and perhaps further....but:
Is the sound quality increasing by the numbers? If not, where are the best performance? E.g. the Zen-2 is simple, but in the zen-5 (push-pull) article the sound is decrribes as equilly to zen-2? Zen-5 is simpler, with no output capacitor....and don't current clip.... Zen-4 (alpeh source) gives more power, but is it outperformed by push-pull (5) with fewer components? Anyone with some opions? |
#2 |
Banned
what speakers?
I like Zen lite best, of those i built. |
#3 |
it all depends on your skills / wants.
Zen 4 has PCB's you can order from PassDIY and Q-packs. An excellent construction article too. You would have a very nice amp if you complete that project. The numbers don't correspond to any kind of rating. One place to start, before spending a penny, would be to download all the articles, print them out, and have a good read... very educational |
#4 |
Thank you....
But all that have been done and the practical matters are of no consern...the one chosen will be hard-wired up. But my aim is sound alone and 10W output.....is a fixed current source better than an Aleph source? In teory is should be like this (my guess): 1. Return of Zen1 (because of fixed source and highest Iq) 2. Zen1(because of fixed source) 3. Zen2 (Aleph) 4. Zen5 (Push-pull) The different powersupply concepts and the input buffer is regarded out of the example, because they can be seen as upgrades for alle above types.... The single-ended people (mostly tube neards), don't regard push-pull, and Aleph could be regarded as an in-between step between single-ended and push-pull? |
#5 |
The one and only
From a purist point of view, some people might not like the
current source modulation of the Aleph, but it is easily adjusted or eliminated, leaving a constant current source. I also have a modulated current source which is voltage dependent instead of current dependent, also adjustable. The problem is that with a single stage and limited bias current, you run into some fairly severe performance hits which are very audible. Modulating the current source reduces these artifacts by factors of 4 or better, and the difference is generally pretty dramatic. I've heard it all sorts of ways, and you have to have a really efficient, high impedance load for the CCS to sound better. I suggest you try it both ways, since changing a resistor is all you have to do. |
#6 |
Than you, I take it as a ZenAleph for best compromise, regarding Zen1 as to low driving power....
And yes, it is easy to switch between both.....when Zen5 have been terminated :-) |
| Amplifier ranking | ralf | Solid State | 150 | 7th July 2010 03:52 AM |
| Amplifier ranking 2 | MikeW | Solid State | 0 | 24th April 2004 12:30 PM |
| Page generated in 0.08772 seconds (77.83% PHP - 22.17% MySQL) with 10 queries |
