What is the best way to connect the differential input of the ALEPH3 to the ground, like Mr PASS, or like Mr KLJUCARIC (pcb design)?
#2 |
Nobody to help me in building my ALEPH3?
#3 |
Both drawings say the same thing.
All of them are just connected to ground. And how the ground lines go in your amplifier is your choice. There are many schools of grounding. Bartek |
#4 |
I find the idea that "Mr Kjularik" should be mentioned in the same page as Mr. Pass as a reference to the Aleph circuit aggravating.
Not to mention the copyright infringment of posting the picutres themselves. Anyway your point about the gnd on the schematic is irrelevant, what matters is how they get done on the PCB which you have no way to establish. You can look at one of Nelson's old PCBs to get a clue. |
#5 |
Grataku, you're right, but on this forum, everybody knows who is "THE MASTER". That's why i permit me to do that. I apologize.
#6 |
Well, my question wasn't very clear. What I would like to know is: must I connect Z102, R103, and C101 together on the board and then going with one wire to the ground star, or must I separate them on the board, and go from the board to the ground star with three wires? On the Aleph3's service manual it's not clear to me. Thanks you.
#7 |
In as much as I can tell, if in doubt, you can't go wrong with running all grounds separately. You should look at the circuit, seeing where current flows are likely to run in loops, and try and avoid low currents grounds, like input stages, being modulated by higher currents grounds, such as outputs or PSU caps.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| Parallel LM3886, input ground, power ground, safety resistor and oscillations. | markiemrboo | Chip Amps | 5 | 9th August 2007 03:50 PM |
| DC filament ground and high voltage ground | mikeyho | Tubes / Valves | 0 | 15th September 2005 05:52 PM |
| Chassis Ground = Circuit Ground --> Problems? | rhildenbrand | Pass Labs | 5 | 23rd April 2004 01:08 AM |
| does connecting mains ground with circuit ground create a ground loop? | jarthel | Everything Else | 0 | 25th June 2003 12:55 PM |
| Should I directly connect my signal ground to chassis ground? | Bricolo | Solid State | 3 | 28th February 2003 05:31 PM |
| Page generated in 0.09142 seconds (74.99% PHP - 25.01% MySQL) with 11 queries |
