Aleph Follower
Aleph Follower
Old 18th October 2017, 04:01 PM   #1
nobody special is offline nobody special  United States
nobody special's Avatar
Default Aleph Follower
I was playing with a few circuits today:
1st: 6W single supply
2nd: 25W single supply
3rd: 25W dc output
What do you think? Anyone try this yet?
Steve
Old 18th October 2017, 04:55 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Aleph Follower
As a concept it will work fine, but this circuit can do that trick without
driving the Gate of the current source transistor. You can feed the output
of the speaker directly to the top of R6.
Old 18th October 2017, 05:22 PM   #3
I guess I'm not seeing it. What exactly do you mean by the output of the speaker?
Steve
Old 18th October 2017, 05:37 PM   #4
I think I have it now:
You have to split R6 up.
Steve
Old 18th October 2017, 05:38 PM   #5
Cool! Thank you, Nelson.
Steve
Old 18th October 2017, 09:38 PM   #6
The one and only
Aleph Follower
Usually the function of Q1 for this is as a constant voltage source (for AC
anyway), so you might want to experiment with filtering its action at audio
frequencies, maybe starting with a big cap across Q1's Collector to Emitter
and maybe increasing R8.
Old 19th October 2017, 01:50 AM   #7
Is the idea to fix the voltage at the gate of the current sink for the DC bias using Q1, and then modulate the Vgs using the speaker current? Is this what the bootstrap is doing on your Aleph source?
Steve
Old 19th October 2017, 02:18 PM   #8
How about using a separate bias network, like this? I know that it removes the bias loop, but it seems better than a cap across the bias transistor. I tried a 5V active reference and it looked very good.
Steve
Old 19th October 2017, 02:35 PM   #9
Or, is it better to switch to a P-channel and just implement the standard type of Aleph sink?
Steve
Old 19th October 2017, 05:00 PM   #10
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Aleph Follower
or you can take upper part of ACA and invert polarity , as lower part of this one
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Aleph FollowerHide this!Advertise here!
Aleph Topology - Power Follower instead Common Source Power output ? tiefbassuebertr Pass Labs 1 26th June 2011 04:15 PM
Aleph 30: adding an emitter follower? fulvio Pass Labs 5 19th May 2011 03:49 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
aleph follower Stefano Pass Labs 8 21st February 2004 03:23 PM
