Build This MoFo!
Build This MoFo!
Old 12th February 2018, 02:46 PM   #741
marconi118 is offline marconi118  Germany
OK I got it now.
Will try this with a bridge rectifier
thank for your help
Old 12th February 2018, 04:52 PM   #742
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Build This MoFo!
So would a frequency dependent LCR meter that shows graph of impedance vs frequency (like DATS) do the same thing?
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 12th February 2018, 05:04 PM   #743
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Build This MoFo!
no way Bubba
you need some electronic apparatus , comparative to Dynamometer in mechanical world
saturation means loaded ......
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th February 2018, 10:11 AM   #744
I measured 30mH starting declining at 2A
what is the safe bias I can go?
Old 14th February 2018, 07:18 PM   #745
Zen Mod's Avatar
Build This MoFo!
no more than 1A5 to 1A7
Old 15th February 2018, 01:42 AM   #746
LBHajdu is offline LBHajdu  United States
If someone wanted to go all out on parts my guess is the Lundahl LL2733 filament current choke may work well. It has two coils which you can put in series or parallel. In series it gives 400mH at a recommended current of 1.7A saturating at 2.7A. Or in parallel it gives 100mH with a recommended current of 3.4A saturating at 5.4A. It's $100 from K&k audio (no affiliation). The LL1694 is also a contender. They claim to wind and gap them as meticulously as there audio transformers and IMO they look sexy if indeed a choke is capable of looking sexy.
Old 15th February 2018, 11:55 AM   #747
sledwards12375 is offline sledwards12375  United States
LBHadju:
The Lundahl 2733 is the choke used in my MoFo monos. See post #669.
Steve
Old 15th February 2018, 01:05 PM   #748
Anchan is offline Anchan  United States
There is quite a range of inductance values between all of these chokes. What is the effect on the circuit as these inductance numbers change? Maybe V = L dI/dt comes into play? But I'm not sure how it all ties together.
Old 16th February 2018, 01:39 AM   #749
Originally Posted by sledwards12375 View Post
LBHadju:
Steve
Apologies sledwards12375 I actually looked at the image, it's well built, but didn't realize it was the Lundahl. I should have looked closer as it's printed on the package.
Anchan if the inductance is insufficient, there will be insufficient magnetic field for it to swing negative getting worst at low frequencies. And swinging positive will also be difficult if it does not have sufficient impedance between the mosfet source and ground. I would need to do an LTSpice simulation to see what it looks like in practice.
Leve
Old 16th February 2018, 09:40 AM   #750
are 30mH ok for 50hz ?
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 10:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 08:12 AM
