Build This MoFo!
Build This MoFo!
Old 12th January 2018, 10:13 PM   #581
Vunce is online now Vunce  United States
Build This MoFo!
ZM,
I was thinking about cutting away the wood base to follow the heatsinks ‘V’ to allow more convection air flow. Currently, they reach 55C at the top of sink.
Old 12th January 2018, 10:17 PM   #582
Stanney2017 is offline Stanney2017  United Kingdom
Noticed the store has sold out of Mo-Fo boards.
Will it be restocked?
Old 12th January 2018, 11:13 PM   #583
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Build This MoFo!
Originally Posted by Vunce View Post
ZM,
cur entire wood protruding/terrace ....... leave just a notch for baseplate of htsnk(5mm or so)
do few slits (router) on bottom plate ....... do same on top plate
it'll be hot in case , when closed ; heatsink is hot at back side ....
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th January 2018, 12:02 AM   #584
Build This MoFo!
Thanks ZM,
I will address the cooling issues before I listen long term. The Big MoFo needs large heat sinks
Old 13th January 2018, 12:32 AM   #585
Zen Mod's Avatar
Build This MoFo!
MoFo! is Big because Mr. MR is having Big Mustaches!
Old 13th January 2018, 03:45 PM   #586
Build This MoFo!
I cut back the base to expose heat sink fins and temperatures dropped
from 55C to 47C :-)
File Type: jpg 39B3AF21-1CC1-4FE0-8B6B-6F1164B382C0.jpg (668.9 KB, 401 views)
Old 13th January 2018, 04:20 PM   #587
Zen Mod's Avatar
Build This MoFo!
Whoa !
that defies physics!!
Old 14th January 2018, 02:13 AM   #588
BeardyWan is offline BeardyWan
I don't think so.
The power dissipated by the electronics is constant. The rate of heat transfer is higher due to more airflow, so all else being equal, the difference between temperature of heat sink and temperature of surroundings is lower.
Old 14th January 2018, 02:44 AM   #589
Zen Mod's Avatar
Build This MoFo!
I can't see anyone claiming differently ......
not counting Will , he' always defying ........ everything
Old 14th January 2018, 09:00 AM   #590
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
I'll recieve 10 boards next week or the week after
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 10:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 08:12 AM
