Build This MoFo!
Build This MoFo!
Old 7th July 2018, 02:32 PM   #1291
sontero is online now sontero  Italy
sontero's Avatar
Originally Posted by Frank40 View Post
I would not be too worried about an offset in the region of 100mV, it will only dissipate 1.25mW in a 8 ohm speaker.
I would test with expendable speakers of little cost ..... before risking the removal of the output cap
Old 11th July 2018, 02:32 PM   #1292
Little_Eddy is offline Little_Eddy
Originally Posted by xrk971 View Post
If you want a very nice high current, low distortion choke that can provide the measured data shown a few pages above, do a search on eBay for a MOT part number "MD-803AMR-1". These measure about 67mH and 0.47ohm DCR.
Coming late to this but always on the hunt for a bargain.
In the UK I have found some MOTs reference MD-803EMR-1. I take it that the specifications are unlikely to be significantly different to the US one above and could well suit this project?
Also if I can get hold of 4, would it be safe to assume that a slightly higher supply voltage to offset the additional dc resistance of two of these in series might be beneficial, or is little sonic improvement likely with double the inductance?
Old 11th July 2018, 02:44 PM   #1293
vitalstates is offline vitalstates  United Kingdom
vitalstates's Avatar
Hi Mike
if that doesn't work out I have 2 hammond 159zc from the mofo you saw at Owston. They won't be doing anything as I'm concentrating on the pp amp. let me know if interested.
There is nowhere you can be that isn't where you're meant to be
www.vitalstates.org
Old 15th July 2018, 07:39 PM   #1294
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Build This MoFo! Send a message via Yahoo to vdi_nenna
Almost got it. Didnt quite nail it.
It's etched. Need to sand it down again.
I build, therefore I am.
Old 17th July 2018, 04:19 AM   #1295
EmeryBB is offline EmeryBB  Australia
Default Hammond 195T5 vs 193V
Gentlemen, which one should I get for the big MoFo? The 193V or the 195T5 (0.1H, 5A and DCR 0.64R). I can get the 195T5 cheaper than the 193V locally.
Old 17th July 2018, 08:04 PM   #1296
jostwid is offline jostwid  Switzerland
I would go for the 195T5 (sufficient inductance, lots of headroom for amperage, lesser DC resistance than 193V)
On the downside:
Postage may be more expensive as it is 50% heavier than 193V
195T5 is open frame....
Old 17th July 2018, 09:47 PM   #1297
e_fortier is offline e_fortier  Canada
e_fortier's Avatar
Build This MoFo!
Even cheaper option is the 159ZC, also open framed. I believe someone on this thread tried it at 2.5A (bias of big MoFo) with no ill effect.
Old 17th July 2018, 09:52 PM   #1298
Thanks Jostwid, I'll order the 195T then. Postage is free actually.
As for being open framed, it doesn't matter does it?
Old 17th July 2018, 10:18 PM   #1299
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Build This MoFo!
I donít think you need more inductance than 50uH to 100uH - it serves to store energy to give a higher peak-peak outpt than available from the rail voltage.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 18th July 2018, 05:46 AM   #1300
MEPER is offline MEPER  Denmark
50 mH - 100 mH …….not uH.
I found an old "MoFo" thread here:
load on source follower choke or mosfet?
Funny to read what they were discussing. Probably before the Pass forum existed?
They discuss air coils and 1:1 transformer output. But no conclusion on how it went…..like no one was finishing their projects. Anybody still here from back then?
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 10:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 08:12 AM
Resources saved on this page: MySQL 66.67% / PHP 45.58%
