Y.A.F5Tv3.B.T. Yet another F5Tv3 Build Thread
Old 19th October 2017, 08:36 PM   #21
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
The jfets aren't that sensitive to Vds.
Your choice.
I would be happy at anything between 13V and 20V on the jfets.
Usually a good rule of thumb is maximum peak input signal + 10V. Assuming 2.8V peak input then 13V is quite good.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 19th October 2017, 10:22 PM   #22
gionag is offline gionag  Italy
Your choice.
Good to know. for 13v is 4k
Old 19th October 2017, 11:00 PM   #23
In the calculation, i have to account the dissipation of the 8 mur3020 ?
from my point of view, they have a very low resistance, so the heat dissipated is quite low... but maybe i am wrong.
From before i have estimate a total power dissipation from the mosfets, but how i need to weight the diodes ? (from a thermal perspective)
Every channel has 8 mosfets and 8 diodes, in the attached simulation i have calculated with a total power dissipation of 140w (and an ambient temp of 30degC).
I think i can push a little bit more on this chunk of aluminium.
File Type: jpg smpl_dissipatore_5314-HGS_5314-Thermal-Thermal1.jpg (298.7 KB, 253 views)
Old 19th October 2017, 11:48 PM   #24
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
in moments of peak currents , current is practically subtracted from mosfets , and given to speaker
so , sum dissipation on heatsink is declining ,so you can ignore dissipation on/through diodes
if you're going full bang , counting on heavy AB class work of F5T , then you really need to carefully calculate everything .....
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th October 2017, 07:30 AM   #25
R.I.P.
Your choice.
the input jFET is a voltage to current conversion stage.
You input a voltage and the jFET output is a current.
The input jFET can operate with a Vds of 2 volts even though the input voltage can swing to over 2Vpk.
If you add on a cascode you can run with a Vds anywhere from ~2Vds to the maximum where base current leakage starts to become unmanagable.
The drain resistor converts the output current back into a voltage read by the next stage.
This drain resistor having a voltage output is what needs voltage to allow that swing.
The drain resistor is above the cascode.
The jFET does NOT need an extra 10V above the input signal.
The purpose of the cascode is to separate the jFET from the effects of the high supply rail voltage.
regards Andrew T.
Old 20th October 2017, 06:28 PM   #26
said that, there is a particular sweet spot for the sk170/sj74 ?
i also imagine that if the cascode device needs to regulate more and more the voltage down then its dissipation figure start to increase. not so much because the current involved are very little...
Old 20th October 2017, 07:44 PM   #27
Zen Mod's Avatar
one can have different understanding , when looking at device load lines graph
in other words - I personally don't like having device starving , neither in voltage nor current
take care to have 10-12V as D-S voltage for JFet , around 90% of Idss and you're there
Old 20th October 2017, 09:52 PM   #28
Don't get confused, just copy Nelson if you don't understand.
I notice that it is usually between 12V and 14V when cascoding.
Old 21st October 2017, 01:03 AM   #29
Nelson seems to use @ 10v on the v3 schematic with 32v rail so i will go with them.
In your opinion, there's a practical way to guestimate the power dissipation that comes from each of 8 diodes (mur3020). I want to optimize a little bit the placement of the whole board assembly on the heatsink and i am thinking to shift a little bit the board to get the most "hot" components (mosfets) in the center.
Old 21st October 2017, 11:18 PM   #30
I was looking into power supply options...
i will start with relatively low bias setting, but i plan to rise as much as possible to extend the class-A region.
Obviously the ripple will rise with it and for limiting the input bulk-capacitance i am start thinking about something like the zenV4 capacitance multiplier / regulator.
I made a sim in spice and it seems to works quite OK. i see that i will loose some voltage and the dissipation is around 25w for 6amp bias (too much... i know).
For sure i need to swap the irfp240 with something more beefier because the power dissipation at startup exceed specs.
What do you think about ?
Y.A.F5Tv3.B.T. Yet another F5Tv3 Build ThreadHide this!Advertise here!
My TABAQ Build Thread Consul Full Range 24 25th April 2016 11:04 PM
How important is N to P ch Mosfet matching for an F5Tv3 nashbap Pass Labs 19 12th December 2014 05:04 PM
Question on Building a separate power supply for F5TV3 nashbap Power Supplies 12 13th February 2014 07:18 PM
transformer for F5TV3 question about Antek AN8234/ AN8434 nashbap Power Supplies 5 9th February 2014 04:33 PM
Sachiko Build Thread! woodturner-fran Full Range 115 9th February 2010 10:11 PM
