Y.A.F5Tv3.B.T. Yet another F5Tv3 Build Thread
Old 1st December 2017, 07:44 PM   #91
gionag is offline gionag  Italy
Originally Posted by 2 picoDumbs View Post
Just for clarification.
Old 1st December 2017, 09:14 PM   #92
Nailed it !
was the Ultrafast diode bridge made with MUR3020...
with plain old GBPC style diode bridge... both of the transformers stopped... (for the moment) any humming...
i guess... in the end... Simple is better
Old 3rd December 2017, 10:38 AM   #93
is there any chance you had the discrete rectifier diodes wired incorrectly?
If they were wired correctly, then the only explanation I can think of is that the larger loop areas of the discrete compared to the integrated bridge would increase interference.
regards Andrew T.
Old 3rd December 2017, 11:12 AM   #94
... I think was a false alarm, i was pretty sure i've solved the winding uhum for good, but yesterday night, when i have fired up again the test bench, the transformer came back in all its humming glory.
So... i think the rect bridge was not the issue.
I will bring the transformers to the factory again and I will ask to re-wind the primary with a 20% more of the nominal flux. I think is a saturation issue.
Attached the bridge i have designed for the discrete mur3020.
C1,2,4 and R1 are not populated
Old 16th December 2017, 10:22 AM   #95
Fast forward almost 2 weeks.
The transformer has been redone, different core, +30% of the nominal primary winding turns.
Now they are dead quiet. just a very little mechanical noise, that i think is quite normal at this load.
Biased at 320mA per device, 55 volt rails filtered 44mF->3.5mH->44mF.
Nulled the second harmonic by distortion analysis. I enjoy a lot the resolution and details coming from this amp. On my speakers, seems a lot sharp but not hard...
Is time to machine some chassis ...
keep you posted !
Y.A.F5Tv3.B.T. Yet another F5Tv3 Build ThreadHide this!Advertise here!
My TABAQ Build Thread Consul Full Range 24 26th April 2016 12:04 AM
How important is N to P ch Mosfet matching for an F5Tv3 nashbap Pass Labs 19 12th December 2014 06:04 PM
Question on Building a separate power supply for F5TV3 nashbap Power Supplies 12 13th February 2014 08:18 PM
transformer for F5TV3 question about Antek AN8234/ AN8434 nashbap Power Supplies 5 9th February 2014 05:33 PM
Sachiko Build Thread! woodturner-fran Full Range 115 9th February 2010 11:11 PM
