Why the Hate for Spades?
Old 12th October 2017, 02:20 PM   #41
fabrice63 is offline fabrice63  France
fabrice63's Avatar
You wont find any kind a spade in aerospace or airplane , military stuff and so on , guess why
after all it's audio , nothing will go really wrong
Old 12th October 2017, 02:25 PM   #42
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Yes, mil spec Amphenol subminiature D with screws and multi pins. You definitely won't find flying leads direct soldered to the PCB.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 12th October 2017, 04:00 PM   #43
JPS64 is offline JPS64  Germany
Sorry, I'm using spades in highest DO160 level qualified airborne developments (french ALAT). No problems, ok, press-fit type.
JP
Old 12th October 2017, 04:20 PM   #44
fabrice63's Avatar
Originally Posted by xrk971 View Post
....... You definitely won't find flying leads direct soldered to the PCB.
sure , because the vibrations , not contact quality
Old 12th October 2017, 08:58 PM   #45
Assesears is offline Assesears  United Kingdom
Used alot in the marine industry but vibration always gets to them, not a big deal to me with my amp boards whatever suits.
Old 12th October 2017, 09:24 PM   #46
Got Foam?
xrk971's Avatar
The female connectors that slip over the spades have a small bump that makes hem almost impossible to remove unless you use pliers to pull off or push the locking bump flat prior to insertion. This is not on all connectors. I wonder if this is what is used to make it more reliable for uses where you don't expect to pull it off again.
Old 12th October 2017, 10:25 PM   #47
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
The locking tab stops them being pulled off but they can still be a sloppy fit if poorly designed. The females vary a lot, some are very good and reliable
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 12th October 2017, 11:41 PM   #48
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Great solution. I wish everyone designing a layout in this forum would do this. Especially the DIYA Store PCBs of Pass amps.
Just use deans plugs.
They are much better than spade connectors.
Gold plated copper, with incorporated spring for very good contact.
Spades are terrible.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 12th October 2017, 11:48 PM   #49
Got Foam?
xrk971's Avatar
With a high quality brand spade connector (TE Connectivity/Faston) the connection quality is excellent with spade connectors. They are much lower profile than Deans connectors and less expensive too.
I might start using the ones that use a crimp tool that clamps the wire as well as the insulation for great strain relief.
http://www.mouser.com/ds/2/418/NG_DS...21-1099709.pdf
Old 13th October 2017, 12:30 AM   #50
helitim is offline helitim  Canada
Hi xrk971,
I use these often in aerospace applications. There are a lot of connection methods that are worse, but my personal preference is the insulated AMP(amphenol) connectors. They hold up better to vibration (probably not an issue for you). They also offer isolation, and in my opinion, they crimp easier/ better. Take my opinion for what it's worth .
Edit: you can buy die sets for most terminal crimpers that will crimp the insulation separately from the wire.
Tim
Why the Hate for Spades?Hide this!Advertise here!
I hate bananas in spades.; Highfido Everything Else 2 17th January 2016 01:43 AM
How do I adapt vintage amp for new spades audiof001 Solid State 4 15th February 2015 06:01 PM
Xhadow Spades silver over copper (4) Doctorcilantro Swap Meet 0 16th June 2014 10:46 AM
Spades, Banana or ??? turboman808 Full Range 13 13th June 2012 08:01 PM
Spades V.s Bananas - what's the story? Peteruk Parts 5 22nd March 2007 02:28 AM
