Why the Hate for Spades?
Old 11th October 2017, 06:47 PM   #11
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
I dislike any kind of convenience connectors in my final assemblies. Meaning the ones I use for actually listening to music.
Call me audiofool or whatever, but I can hear the difference with and without them.
This includes interconnects, source switches, and the like. I would even remove the volume control if I lived in an isolated residence
Having a testbed assembly is a different discussion. There I usually prefer double screw connectors on cables
I believe spade connectors are only mandatory on mains connections.
As for lifting pads, designing them reinforced is always a good idea
Here is a closeup of the part footprints that I am using
Why the Hate for Spades?-capture-png
Too many projects... so little time...
Old 11th October 2017, 06:48 PM   #12
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Originally Posted by scottjoplin View Post
I like them so long as the locking receptacle isn't used. They have a large contact area.
Actually a spade connector only has a gas-tight joint along the edges of the rolled-in sides of the female connector. All the other bits of it will oxidise and become high-resistance.
Old 11th October 2017, 06:49 PM   #13
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Maybe that is the problem: I don't consider any amp I build, my final amp.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 11th October 2017, 06:51 PM   #14
Got Foam?
xrk971's Avatar
The flat in the middle makes a pretty tight (maybe not gas tight) connection too - this is where the locking bump/tab is. But when I look at the flats on my spade after pulling them out, the flat is shiny from mechanical wear during insertion/removal process.
Old 11th October 2017, 06:54 PM   #15
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Yep, as I said, large contact area and under sprung tension too, better than any screw terminal
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 11th October 2017, 06:59 PM   #16
JeffYoung's Avatar
I think you'll find that the flat in the middle does not stay shiny after insertion and before removal.
That being said, I do agree with Scott that a sprung connection is better than any screw terminal.
Speaking of which, I use wave washers under my transistor mounting bolts. However, I suspect that at these small dimensions they don't really have any effect. Anyone else?
Old 11th October 2017, 07:00 PM   #17
radtech is offline radtech  United States
I service one type of equipment that uses faston type terminals for several things. I've replaced lots of them for loosening up or becoming oxidized and overheating. They have their uses, but not reliable long term.
Old 11th October 2017, 07:02 PM   #18
I use these Belleville washer - Wikipedia
Old 11th October 2017, 07:10 PM   #19
WalterW is offline WalterW  Netherlands
I have used spades in my latest VFET-X build also, but always in mind to solder them together, after the amp is totally finished.
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 11th October 2017, 07:45 PM   #20
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Aluminium materials in your pre or amplifier audio path ?
File Type: jpg E38CE5C1-FA03-4C65-9B2B-5F79FB831F29.JPG (655.5 KB, 376 views)
class A amplifiers with full range speakers
sings like angels in heaven
Why the Hate for Spades?Hide this!Advertise here!
I hate bananas in spades.; Highfido Everything Else 2 17th January 2016 01:43 AM
How do I adapt vintage amp for new spades audiof001 Solid State 4 15th February 2015 06:01 PM
Xhadow Spades silver over copper (4) Doctorcilantro Swap Meet 0 16th June 2014 10:46 AM
Spades, Banana or ??? turboman808 Full Range 13 13th June 2012 08:01 PM
Spades V.s Bananas - what's the story? Peteruk Parts 5 22nd March 2007 02:28 AM
