Old 30th March 2004, 05:44 PM   #1
PsykoK is offline PsykoK  France
Send a message via ICQ to PsykoK Send a message via AIM to PsykoK
Default Bias Resistor for AX
I search some good 0.33R 3W resistor to build an AX.
I found this:
http://www.caddock.com/Online_catalo...000_Series.pdf
www.distrelec.ch ref: 721705 or 720703
What do you think about these parts?
With 1% tolerance must I match them?
Tanks in advance.
Alex
Old 30th March 2004, 05:49 PM   #2
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Seems like a very nice resistor. I wouldn't bother matching them at 1% quoted tolerance.
Personally, I just used four 1.3Ω 1W BC Components metal film resistors in parallel to get 0.33Ω. Only costs US$0.34.
Old 31st March 2004, 04:08 PM   #3
Tubie Noobie
Default Parrallel Resistors
In my AX, I needed .4ohms. In order to do that I found .82 ohm 2watt MOX resistors. Used two per device. Since they were 5% tol, I measured them.
What was interesting was looking at the actual tolerence. Out of 200 resistors, only 4 were over 1% deviation. Infact the general population of the the groups was better than 0.5%. This supports not needing to measure 1% tol resistors. Of course we are DIY, why not measure them.
I used a method I saw on the forum of attaching 10 in series and passing 1 amp of current through them. The voltage drop across each device is equiv to the resistance in ohms. I was able to measure all of them in about 4 hours.
By selecting the resistors to use, the effective tolerence for the resistors is theoretically 0.01%. In reality, I think my meter has more error than that.
I did a similar thing for the current sense resistors and the ground resistors as seen in the photo
Scott
Old 31st March 2004, 04:40 PM   #4
jwb's Avatar
I love the half-circle terminals you built on those capacitors. Bravo.
Old 31st March 2004, 04:59 PM   #5
SGregory> Nice work!
Thanks for your information!
Alex
Old 31st March 2004, 05:10 PM   #6
jam is offline jam  United States
jam's Avatar
Scott,
I like the way your construction looks. How about more close up photographs.
Jam
bias resistor to use for a PP 300B? jonusgrumby Tubes / Valves 1 12th January 2009 09:48 PM
cathode resistor ?? in p-p fixed bias richwalters Tubes / Valves 12 28th August 2007 11:26 PM
Bias resistor nhuwar Tubes / Valves 14 19th January 2007 06:21 PM
Cathode bias resistor value for 6SN7? kegger Tubes / Valves 10 9th August 2006 09:09 AM
Bias with a resistor DSP_Geek Solid State 1 2nd September 2004 11:31 PM
Page generated in 0.07899 seconds (73.53% PHP - 26.47% MySQL) with 11 queries
