Old 30th March 2004, 11:10 AM   #1
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Default simple power supply question.....
Im building an XBOSOZ and have a 60 0 60 transformer. It has 3 secondary windings one is a centre tap, not two pairs of windings.
Can I use two bridge rectifiers to get plus minus rails or can I only do this with one? I get a buzzing and warm transformer when I try using 2 bridges
cheers ab
Old 30th March 2004, 11:26 AM   #2
Default Re: simple power supply question.....
cheers ab
Luke,
You may have the polarity of one bridge reversed. Are you getting close to 90 volts dc out of each side?
I normally would wire one of these for dual rail, -90 +90 volt operation.
George
Old 30th March 2004, 11:29 AM   #3
Ouroboros's Avatar
This is the normal way to use a CT winding with a bridge.
Old 30th March 2004, 11:49 AM   #4
thanks for your replies.
Panelhead, I dont think I have polarity reversed, Im quite tired and will check again tomorrow
Ouroboros, I know this method, but want dual bridges if possible, Im not sure it is?
Old 30th March 2004, 12:02 PM   #5
Ouroboros's Avatar
With totally split secondaries, then you can use two separate bridges. If you try to do that with a CT winding, you'll find that you're shorting different diodes out on +ve and -ve half-cycles of the mains.
(Just draw out the route the currents take and you'll see it. Your transformer would be getting a bit warm!)
Old 31st March 2004, 07:22 AM   #6
hi Ouroboros,
thanks, yes i get it now Was tired last night but Ive had another look tonight and drawn it out. Makes sense. Not sure wether to get another tx or go with one bridge?
thanks for your help arthur
simple power supply schematics getafix Chip Amps 8 12th October 2007 10:41 AM
Cmoy power supply simple question wiredmonkey Chip Amps 2 17th July 2007 01:44 AM
simple bipolar power supply BodomChild Power Supplies 4 12th July 2006 08:25 AM
Simple toroidal power supply assembly question wigginjs Solid State 0 2nd July 2004 06:41 PM
simple power supply question zobsky Parts 11 10th April 2004 01:00 PM
Page generated in 0.10689 seconds (63.27% PHP - 36.73% MySQL) with 11 queries
