Nelson Pass F3 amplifier help wanted
Old 31st August 2017, 02:42 AM   #1
russell66 is offline russell66  Australia
Default Nelson Pass F3 amplifier help wanted
Hello
I am wondering if anyone can help me fix this amp. I have a limited understanding but it seems pretty simple. I understand the transformer, then there is what I think is a PSU with various caps and then the Amplifier circuit. The black resistors on the top are smoking when it's switched on. Someone has replaced one channel at one point with different resistors which seems to work ok. I have replaced 3 resistors also but still got the same issue. I would like to put it in a better chasis and perhaps improve some parts if needed. Boards and that sort of thing are available cheaply from China and it would seem better to buy something than spend money on finding the problem as that is expensive. Thats if I knew what to buy. I tried to post some pics but couldn't so i made a short video. Thanks for any help.
Heres the video link.
YouTube
Old 31st August 2017, 03:03 AM   #2
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
What are the black resistors connected to?
Post a circuit diagram circling the parts on the diagram that are giving you trouble.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 31st August 2017, 04:36 AM   #3
I don't have a circuit diagram or know how to get one. I think it is a standard pass circuit.
Old 31st August 2017, 05:33 AM   #4
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
It is most probably a ZV9 on Veteran's PCB.
http://www.firstwatt.com/pdf/art_zv9.pdf
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 31st August 2017, 05:38 AM   #5
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
This is not a Nelson Pass F3, it's a Tim Rawson rip off.
First Watt Clone f3 by Tim Rawson - Audio Asylum Trader
No wonder it's not working.
Gravity - Making the G since 13.7 billion B.C.
Old 31st August 2017, 08:49 AM   #6
Pretty sure Tim based his work on the design that was made available to the DIY community by Nelson Pass and it does look just like that one so I'm thinking that's it.
Do you know the circuit diagram or is the one in the above post accurate.
Perhaps just to clarify because I think your onto something.
If its a Tim Rawson rip off that suggests its a copy of a Nelson Pass F3 which means it is an F3 build by Tim. If it's not an F3 and it's a Tim Rawson rip off, then that means its a Tim Rawson's own design which means I won't find the circuit in the Pass F3 arena. Would you know which of those is accurate? I'm sure it's the first in which case it is an F3. Thanks
Old 31st August 2017, 09:54 AM   #7
Take a close up photo and circle the offending components.
Use photobucket to embed the images
Old 31st August 2017, 09:55 AM   #8
If you live in Melbourne I can come and look at it for you.
Old 31st August 2017, 10:27 AM   #9
Dennis Hui is offline Dennis Hui  Canada
Looks like Peter Daniel's F3 board. For example, see here:
F3 PCB + Lovotech 1016
There were a number of group buys for this pcb so you should be able to find out more.
You can also download the f3 schematics and visually check how well it matches your pcb.
Should also add that if it is a Peter Daniel pcb is should be very close to the published schematics, but
with some minor changes like removing the led and maybe adding some bypass cap.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 31st August 2017, 10:44 AM   #10
I compared the pcbs.
They are similar to Peter's pcb but there are differences.
Nelson Pass F3 amplifier help wantedHide this!Advertise here!
A Concise Guide to the Published Amplifier Circuits of Nelson Pass rsdio Pass Labs 52 17th May 2018 09:48 AM
PCBPCBs for Nelson Pass‘ CSX1 SONY VFET amplifier permaneder Group Buys 425 17th February 2018 04:12 PM
Nelson Pass Forte Audio Model 3 Amplifier zaum Swap Meet 2 10th November 2016 04:45 PM
New Amp "ULTRASYMMETRY" from Nelson Pass - still a Concept Amplifier? tiefbassuebertr Pass Labs 23 30th October 2012 08:02 AM
build amplifier F1 of Nelson Pass philharmonie Solid State 0 2nd March 2010 03:41 PM
