Nelson Pass F3 amplifier help wanted
Old 31st August 2017, 11:04 AM   #11
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
FIRST WATT F3
Old 31st August 2017, 11:34 AM   #12
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
As far as I know, F3 and ZV9 almost the same.
Wanted: F3 pcb - anyone?
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 31st August 2017, 11:53 AM   #13
russell66 is offline russell66  Australia
No way your a legend! I am in Perth, if I will be in Melbs in November but hopefully we can sort it before then. Ill upload the pictures and post them tonight. Thanks
Old 1st September 2017, 05:33 AM   #14
Old 1st September 2017, 05:34 AM   #15
Its these 3 resistors that glow red and smoke. Click the image to open in full size.
Old 1st September 2017, 05:40 AM   #16
In this picture you can see a previous repair on the left by a technician which seems to work ok. I'm not sure if he did anything else or if it changes the sound. On the right you can see I have replaced them with three new ones but the problem is still there.
Old 1st September 2017, 10:57 AM   #17
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Maybe your components on right side board make electrical short contact with the heat sink ? Blue square trimmer around run hot resistors viper position is ~ similar to trimmer on the left side ? Transistors N and P channel is in correct position if compare with the other working board ?
Greetings
class A amplifiers with full range speakers
sings like angels in heaven
Old 1st September 2017, 11:18 AM   #18
Soundhappy's Avatar
Werify all wires if not wanted contacts maybe red and black have short or is separated correctly ?
File Type: jpg 738E4D8A-C30F-40DD-BD5F-4FCA2F3938EE.JPG (238.1 KB, 142 views)
Old 1st September 2017, 01:05 PM   #19
Dennis Hui is offline Dennis Hui  Canada
Looks like there are no standoffs on the board and it doesn't look like much spacing
between the PCB and heatsink. Please check if something may have shorted from
behind the PCB.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 1st September 2017, 04:59 PM   #20
Gyuri's Avatar
Good point.
If I were you, I would break it apart and, after checking the parts, I would build it properly
Nelson Pass F3 amplifier help wantedHide this!Advertise here!
PCBPCBs for Nelson Pass‘ CSX1 SONY VFET amplifier permaneder Group Buys 428 27th May 2018 02:25 PM
A Concise Guide to the Published Amplifier Circuits of Nelson Pass rsdio Pass Labs 52 17th May 2018 09:48 AM
Nelson Pass Forte Audio Model 3 Amplifier zaum Swap Meet 2 10th November 2016 04:45 PM
New Amp "ULTRASYMMETRY" from Nelson Pass - still a Concept Amplifier? tiefbassuebertr Pass Labs 23 30th October 2012 08:02 AM
build amplifier F1 of Nelson Pass philharmonie Solid State 0 2nd March 2010 03:41 PM
