ZEN working
ZEN working
Old 30th May 2001, 02:20 AM   #11
GRollins is offline GRollins  United States
Jam,
Increasing the drive is a good idea, but I don't think it's the cure to this problem as the sonics were pretty much the same even at low volume, hence not drawing grid current (AB bias).
Mind you, the sound of the amp would probably have satisfied a lot of people, even with the current source(s). It's just that I was determined to do better, sonically. Resistors happened to be the solution. One of these days, I'll get around to trying a resistor (& negative rail) under the front differential...when I get time...
Grey
Old 30th May 2001, 02:30 AM   #12
jam is offline jam  United States
jam's Avatar
Default Supply for current source
Grey,
A volatge doubler taken off the bias supply might work, assuming that you are not using a self bias output stage.
Jam
Old 30th May 2001, 04:06 AM   #13
Jam,
Now, that's an idea that I can live with!
(Clearly, you aren't going to be happy until you've got me working 48 hours a day...*sigh*...actually, I'm smacking myself in the forehead for not thinking of it myself.)
I'll have to drag out the schematics and see what the raw AC going into the bias regulator is, but it should work just fine.
Grey
ZEN workingHide this!Advertise here!
Amp non working covik Solid State 0 12th November 2006 08:12 PM
WTB Krell KSA Mk2- working or non working Jozua Swap Meet 0 20th March 2006 11:14 AM
sub amp not working felzi Chip Amps 0 28th July 2005 05:29 AM
p3a not working, help! benmanf Solid State 9 27th May 2005 01:02 PM
Copyright ©1999-2017 diyAudio
