Help me with this toroid!
Old 10th August 2017, 09:03 PM   #21
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
If they were out of phase, you would really know it.
Old 10th August 2017, 09:11 PM   #22
Hikari1 is offline Hikari1  United States
Ah, I understand. Pretty sure they were out of phase in the "R&D" phase of this project.
Light bulb limiter came in handy.
F5T is up and running now w/32V rails (30.9 loaded) and dual pairs of Toshiba Mosfets. Bias is 1.8A per channel.
I think I liked it better at 24V rails and 2.4A bias. But the headroom is nice.
Bias is certainly king if you don't need the power.
Old 11th August 2017, 12:02 AM   #23
CanAm Man is offline CanAm Man  United States
If they were out of phase, then either you would have:
1. Effectively be a "bucking transformer", with zero volts appearing on the secondary windings--if only for an instant of time...(!)
2. You would have created a cold fusion thermo-cryogenic reactor.
Only kidding--with the voltages you have on your current (no pun intended) secondaries, you are OK--you have the primaries "in phase"..... As an aside, if you even wanted/needed/desired a higher rail voltage, you could use the 100v primaries, rather than the 120v primaries, to get a rail voltage that was about 20% higher. (However, noo need to try this for your amp...)
Old 11th August 2017, 08:03 AM   #24
R.I.P.
Using a 110Vac, or 120Vac supply into a 100Vac rated primary is likely to saturate the transformer (especially any of the continuous lamination cores) and lead to severe overheating.
It is OK to go the other way: use a lower supply voltage into the higher rated primary. The only downside is a reduction in the effective VA.
The manufacturers provide tappings to avoid those problems.
A multi-tapped primary usually has windings in 5Vac increments.
100, 105, 110, 115, 120 would be typical for a transformer that can be used on any supply voltage from 97.5Vac to 122.5Vac
And with the correct tapping selected the transformer will be within 2.5Vac of it's rating.
This minimises the risk of saturation and maximises the available VA.
If it was a dual primary, then it now covers the range from 197.5Vac to 242.5Vac in 5Vac increments.
regards Andrew T.
Old 12th August 2017, 10:16 PM   #25
Good point, Andrew..... Either use (as a bucking transformer to reduce output voltage, or using a lower-voltage primary to step up the output voltage) aren't sound engineering techniques..... I've used them before--but only on breadboards and for prototyping--when I didn't have the appropriate transformer on the shelf.
Neither are an "optimal approach" for a best-practice design.
Help me with this toroid!Hide this!Advertise here!
winding a torroid ?? Minion Power Supplies 7 22nd October 2011 10:58 PM
need help picking torroid oiphy Power Supplies 2 13th September 2011 05:11 AM
Q on torroid mounting weinstro Power Supplies 3 25th January 2006 12:22 AM
small crack in torroid!!future of torroid? sagarverma Power Supplies 24 8th November 2005 04:22 PM
Torroid vs. SMPS ChocoHolic Power Supplies 55 21st August 2005 01:34 AM
