Help me with this toroid!
Old 24th July 2017, 05:53 AM   #11
Hikari1 is offline Hikari1  United States
Thanks everyone for the help.
Old 24th July 2017, 07:16 AM   #12
R.I.P.
Switch on. You can now measure the voltages between all the other tappings.
check the voltage across the primary taps.
This lets you check you have wired them correctly.
regards Andrew T.
Old 31st July 2017, 06:03 AM   #13
I've got it up and running and connected to the cap bank. I am reading 34V rails unloaded. How much voltage drop can I anticipate when loaded (F5T, 2A bias)? Hoping for 32V rails.
Old 31st July 2017, 08:24 AM   #14
R.I.P.
Is the 34V the DC voltage at the amplifier power terminals, when the amplifier is set to zero bias current?
Or is it the voltage stored on the PSU capacitors when there is no load on the PSU?
regards Andrew T.
Old 31st July 2017, 11:21 AM   #15
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
estimate 1.25 x Vac , when loaded
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 31st July 2017, 02:32 PM   #16
Measured at the last cap in the cap bank. The amp boards are not installed yet.
Old 31st July 2017, 02:40 PM   #17
R.I.P.
Then expect it to drop when you connect the amp. It might lose a couple of volts.
As you bias the output stage it will drop more, maybe 4 to 5 more volts.
i.e. 34 - (2+5) = 27Vdc
regards Andrew T.
Old 31st July 2017, 04:04 PM   #18
Great. Thanks. Here's a pic. Thanks all for the help.
Old 31st July 2017, 04:11 PM   #19
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Additional options in this thread:
A little tester to determine transformer PhaseDots with no scope or signal generator
If you've got a signal generator and a scope,
(You could also use a protoboard + NE555 oscillator instead of the signal generator)
Old 10th August 2017, 07:23 PM   #20
The amp is up and running with 30.9v rails.
Admittedly, Iam not sure if the transformer primaries are in phase. Does it really matter? What are the drawbacks when out of phase?
Help me with this toroid!Hide this!Advertise here!
winding a torroid ?? Minion Power Supplies 7 22nd October 2011 10:58 PM
need help picking torroid oiphy Power Supplies 2 13th September 2011 05:11 AM
Q on torroid mounting weinstro Power Supplies 3 25th January 2006 12:22 AM
small crack in torroid!!future of torroid? sagarverma Power Supplies 24 8th November 2005 04:22 PM
Torroid vs. SMPS ChocoHolic Power Supplies 55 21st August 2005 01:34 AM
