diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   what type of inductor (http://www.diyaudio.com/forums/pass-labs/30935-type-inductor.html)
MEGA_amp 25th March 2004 05:24 PM
Progress is slow going on my Aleph 2. I looked around but, i'm looking for a definitive answer about what type of inductor to use.
I've been looking at 12 ga. air core 2.2mH inductors. What are the advantages/disadvantages of using this type of inductor vs. the foil type inductor? From what i've read foil is better than regular wire wound inductor.
Thanks in advance
John
MEGA_amp 25th March 2004 08:09 PM
Shoulda looked harder
http://www.diyaudio.com/forums/showt...106&highlight=
I've seen people using the foil type, but is it preferred soundwise overall, compared to the wirewound aircore.
John
Brian Donaldson 25th March 2004 08:20 PM
The only real concern is to keek the resistance down so the thing doesn't melt the insulation and short. I don't see how the conductor's shape (wire or foil) could make a difference. It's only filtering 120 hz ripple and is decoupled from the amp by the second bank of caps
Panelhead 25th March 2004 09:02 PM
Re: what type of inductor
Thanks in advance
John
For power supply filtering, I have been using cheap ferrite e-core chokes. The advantage is size and cost.
For something like a Aleph 2, an air core choke of 2.2 mH and a current capacity of 10 amps or so is very large.
My amps are much lower current than a 2, but a 2.7 mH, 6 amp choke was 5.95 at the local emporium. It would fit in your hand, 2 -3 pounds.
George
GRollins 25th March 2004 09:43 PM
My two cents worth is that the foil inductors would be wasted. Use regular wire inductors. Save the foil inductors for your speakers.
Grey
MEGA_amp 25th March 2004 09:49 PM
Why is it always a penny for your thoughts, but you put your two cents in, somebodys making a penny here.
---steven wright
Thanks for the info
JH
Magura 25th March 2004 10:04 PM
2.2mH air core 600W inductors are actually not that big. I made a few a while ago. For lots of power theyre un-beatable.
Magura:)
GRollins 26th March 2004 12:18 AM
There's a sign tacked on the wall here at work that says,"Every minute you're mad, you've lost a second of happiness."
I want to know what happened to the other 59 seconds.
Grey
Magura 26th March 2004 12:34 AM
---steven wright
Thanks for the info
JH
2 cents is almost the same as a penny.....you see the reason it turnes out to be 2 cents and not 1.8 cent, is the exchange fee of the bank.
Magura:)
moe29 26th March 2004 03:05 AM
2 Attachment(s)
These are the inductors i used in my Aleph 2. They're 2mH.
I used to get them from MCM... but they quit stocking them, last time i looked.
Resources saved on this page: MySQL 18.75%
