Old 23rd March 2004, 08:15 PM   #1
Lightbulb Phase of Pass Labs amps!
Long time ago I red an Accuphase's article on the net. It said that the phase (or degree of phase inversion) is of most importance for the correct reproduction of instruments timbre. In Nelsons writings I didn't saw anything about phase invertion at the ends of frequency response (high and low frequencies). One University did a research on how do we react on inverted phase below 100Hz, and they said we hear that as unnatural sound, even unrecognizeable. Can someone (maybe Nelson) tell me something more about that in Pass Labs amplifiers. I would also like to hear your opinions on this subject.
Old 23rd March 2004, 08:28 PM   #2
The one and only
Nelson Pass's Avatar
Pass Labs products do not invert phase, although the
original Zen design (not a real product) explicitly does.
Old 23rd March 2004, 08:59 PM   #3
How do you achieve that? I mean, is phase invertion something you are trying to avoid in an amplifier with adding something in a circuit, or there just isn't phase invertion because of a good circuit construction?
Old 24th March 2004, 01:17 PM   #4
Default What about phase distortion?
Is "phase distortion" similar to "phase invertion"? Somewhere on this forum I red that some Pass amps and preamps have phase distortion of 5 degrees. Is that true? Can that be void? Is it important at all for the music reproduction?
Old 24th March 2004, 01:51 PM   #5
www.audiohobby.com
Are you perhaps asking about phase shift rather than phase inversion?
Old 24th March 2004, 02:17 PM   #6
yes (I guess)! I don't know the proper word. What is the phase shift? Give me just brief explanation!
Old 24th March 2004, 05:12 PM   #7
uli is offline uli  Austria
Default phase shift
an ideal amp with a frequency range of Zero to Infinite
wil have theoretically zero degrees of phase shift.
If you insert poles you get some degree of phase shift:
the input dc-blocking caps add some phase shift to the
lower range of the signal. therefore good designs start
either at pure dc (e.g. X1000) or at the lowest possible
frequency. this cap produces 45° phase shift at its pole
frequency. the same is true for the upper end of the ampīs
range. therefore designers try to make these poles about
the factor 10 away from the audible range thus reaching
phase shift which is very lo, about 5 degrees or so
An amp with ideal square wave reproduction (0 - oo Hz)
does not necessarily sound perfect. this means that in
real life you always have to accept imperfect solutions
the art of design lies in the perfect blend of those imperfections
just as e.g. a SE power amp with one 300B or an Aleph 2!
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 24th March 2004, 05:22 PM   #8
www.audiohobby.com
Very lucid explanation, Uli
Old 24th March 2004, 05:44 PM   #9
tx!
Uli
Old 24th March 2004, 06:27 PM   #10
What about Aleph 5? I didn't find any info. Is there any way to minimise phase shift in this circuit without making it sound worse?
PS: Thanks for nice explanation!
fullrange speakers and Pass labs amps MikeW Pass Labs 41 23rd March 2008 11:59 AM
Powercords and effects on Pass Labs amps mert Pass Labs 19 5th July 2007 11:12 PM
Recommend a Good Preamp for Pass Labs Amps misterdoggy Pass Labs 4 20th January 2007 04:43 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
Page generated in 0.09731 seconds (80.25% PHP - 19.75% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
