"Light Touch" Class A Amp - Page 3 - diyAudio
Old 11th May 2017, 06:57 AM   #21
wrenchone's Avatar
The results of all this messing around will also be applied to my "Amp Cramp" project, which would benefit. I wonder if Papa still has the Kleinhorns - I'd like to turn the little cramper loose on them.
Old 11th May 2017, 05:03 PM   #22
The one and only
Nelson Pass's Avatar
The Kleinhorns were donated to an artists collective in the Bay Area some
years ago. These days I would hook it up to the Tannoys at 95 dB. They
get reasonably loud at 1 watt.
Old 11th May 2017, 05:36 PM   #23
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th May 2017, 05:37 PM   #24
wrenchone's Avatar
Too bad, but the Tannoys probably occupy a heck of a lot less cubic.
As promised, here's a simulation with the values of feedback resistors R1 and R3 whacked in half - R3 goes from 1.8k to 910R, and R1 from 100R to 47R. The gain remains the same at 18dB, or 8X. Current in the p-channel rises to 16 mA. Dissipation in the p-channel is a whopping 60mW, totally ok even for a plain TO-92, cruising for the Zetex/Diodes, Inc. E-line package, which is good for about 0.5W for a sane temperature rise.
As can be seen, distortion goes down compared to the previous example and is still dominated by 2nd and 3rd harmonics. However, it doesn't go down that much, leading me to believe that I'm approaching the point of diminishing returns - time to declare victory and go home..
Old 11th May 2017, 05:42 PM   #25
Vix is offline Vix  Yugoslavia
Vix's Avatar
Somebody could think that Tannoy stands for a tiny speaker Everything is relative
Old 11th May 2017, 05:43 PM   #26
wrenchone's Avatar
Lots of things would look small compared to the Kleinhorns...
https://www.passdiy.com/project/spea...einhorn-part-1
Old 12th May 2017, 12:40 AM   #27
wrenchone's Avatar
Post #24 has the wrong schematic and the right harmonic profile - let's try again, shall we?
Old 13th May 2017, 12:29 AM   #28
2 picoDumbs's Avatar
I haven't used IRFP360 before, I quite like IRFP250.
Have you tried 250 vs 360?
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 13th May 2017, 12:45 AM   #29
wrenchone's Avatar
The IRFP360 in the simulation is a placeholder for the IRFP260, my go-to monster fet. I have some IRFP150s, but would rather use the 260 to get the better junction-to-case thermal resistance and higher transconductance (one size larger die). The 150 would work, but I imagine the bias point would be a little different. Adding the variable bias setting in the bottom of the input resistor would likely make switching between output devices relatively painless.
Old 13th May 2017, 12:59 AM   #30
wrenchone's Avatar
I just finished running the latest circuit at 16 ohms and 4 ohms load - the default so far has been 8 ohms. At 16 ohms, the gain goes from X8 to X10, and the THD goes from ~0.2% to 0.48%. At 4 ohms load, the gain goes down to X6 from X8, and the distortion goes up to 1.14%, still dominated by 2nd and 3rd harmonic.
Roksan Kandy MKIII AMP won't come out of "mode" - green light. chrisjoanne Chip Amps 1 10th February 2015 12:52 PM
Building "The Wire AMP" Class A/AB Power Amplifier" wirewiggler Solid State 13 24th January 2015 12:22 PM
Final doubt on CarlosFM like PSUs ("light" or "complex v3")? tent Chip Amps 17 20th November 2014 10:17 AM
"WTB" "The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral enantra Swap Meet 3 23rd December 2012 06:36 PM
Copyright 1999-2017 diyAudio
