Old 22nd March 2004, 02:17 PM   #1
hacknet is offline hacknet  Singapore
Default Choke Loaded Zen
sorry for the silly question but would having too much inductance have ill effects on the amp?
how does one come to the figure of 50mH?
Thanks in advance!
Old 22nd March 2004, 03:25 PM   #2
Magura is offline Magura  Denmark
Magura's Avatar
How wonderful to find somebody as ignorant as myself
If you look at the choke loaded XSOZ thread, youll find me asking the same question, and somebody spelling out the answer.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 22nd March 2004, 03:25 PM   #3
azira is offline azira  United States
Because you would suddenly have a 3-cu.ft. amp that weighs 150 lbs. Most of these amps are large 'cause of heat sinks but that would be a litlte much..
Actually the larger the coil, the lower the low frequency rolloff, so you would ideally want a very large value, but there are limits of practicality to think about.
large coil also helps for PS filtering in the same way it extends low freq response..
Old 22nd March 2004, 10:07 PM   #4
The one and only
Nelson Pass's Avatar
Default Re: Choke Loaded Zen
I used about 1 Henry, as I wanted some bottom end. 50 mH
is only going to give you about 6 ohms worth of reactance
at 20 Hz. If you're operating above 100 Hz, it probably
would be perfectly adequate.
Old 22nd March 2004, 10:49 PM   #5
Magura's Avatar
Not that i remember the formula, but to get 20Hz into 8 ohm, you will need a 80mH inductor.
Magura
Old 22nd March 2004, 11:39 PM   #6
Magura's Avatar
After quite a search, i found the thread i told about in an earlier post.
Choke Loads for Zen/Aleph Amps
Magura
Old 28th March 2004, 07:30 AM   #7
sorry for the late reply...
i think 80mH isn`t too hard. it seems rather possible.
thanks for the link!
Old 29th March 2004, 07:43 AM   #8
djk is offline djk
djk's Avatar
Speakers with very low Qts are quite efficent and frequently vented.
Think classic Altec, JBL.
Venting these drivers to 30hz~40hz causes a peak in the impedance in the 60hz~70hz region.
It may be needed to add a 30 ohm resistor in parallel with the speaker for best operation.
Play it by ear.
Note:
This helps PP tube amps with small iron too.
Old 30th March 2004, 07:27 AM   #9
hmm... i see the problem. i`m looking at increasing the impedance...
Old 30th March 2004, 04:26 PM   #10
Tyimo is offline Tyimo  Hungary
Hi!
Do we speak about this?
Is the 100 mH enough also on 6 Ohm speakers?
Choke loaded LTP jane Tubes / Valves 6 8th November 2008 02:25 PM
Hum on a choke loaded stage Sandor Tubes / Valves 0 28th April 2007 09:16 PM
Choke Loaded ZenV8 RAM Pass Labs 2 30th September 2006 02:01 AM
X-SOZ-X-BOSOZ.....choke loaded Magura Pass Labs 23 27th February 2004 04:38 PM
Is this a choke loaded Xsoz? Fuling Pass Labs 10 31st January 2004 12:20 PM
Page generated in 0.10416 seconds (76.19% PHP - 23.81% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
