Pass B1 pre with BF862
Old 2nd August 2017, 06:45 PM   #81
kinku is offline kinku  United States
Can't change anything by doing anything else In any useful way .
Old 4th August 2017, 07:56 AM   #82
R.I.P.
adding a resistor to the source of both devices reduces the Id and thus reduces the Pq.
That ends up looking like the style promoted by D.Feucht rather than the simpler B1/DCB1
regards Andrew T.
Old 4th August 2017, 12:45 PM   #83
ApolloZhang is offline ApolloZhang  Europe
Hi Andrew,
will this method increase the noise seen by the load? The 862s have really low noise, if lower Idss is needed one can simply use bf861, which looks quite similar to 862.
Old 4th August 2017, 01:49 PM   #84
Does anyone know the real noise figures in dB of BF862, NXP has not published a plot of the noise figure and I don't know how to interpret nV/root Hz .
Old 4th August 2017, 02:32 PM   #85
R.I.P.
Output noise = Stage gain * sqrt(bandwidth) * Ein
If Ein is 1.2nV/rtHz and the stage gain is 1times (-0dB) then for a 20Hz to 20kHz bandwidth the output noise due to Ein is:
1 * sqrt( 20000 - 20) * 1.2 = 1* 141 * 1.2 = 169nVrms
Now compare to a power amplifier with an Ein = 10nV/rtHz and a stage gain of 27times
Output noise due to Ein = 27 * 141 * 10 = 38070nV = 38uVrms ~ 0.04mVrms
regards Andrew T.
Old 4th August 2017, 02:37 PM   #86
R.I.P.
Originally Posted by ApolloZhang View Post
..........will this method increase the noise seen by the load? ............
Almost not at all.
regards Andrew T.
Old 4th August 2017, 03:08 PM   #87
Thanks Andrew, how will you convert nV/root HZ to dB ?
Old 5th August 2017, 09:29 AM   #88
R.I.P.
Signal to Noise Ratio = 20log(Signal/Noise)
If your signal is for 1W into 8ohms, then Signal = 2.828Vac = 28280mVac
Noise = 0.04mVrms
S/N = 20log(28280/0.04) = 97dB ref 1W for a 10nV/rtHz power amplifier.
regards Andrew T.
Old 9th August 2018, 12:50 PM   #89
Niceonecyril is offline Niceonecyril  United Kingdom
Default 2 Stage B1 with BF861B and BSC network
Dear diyers,
I was thinking of building a 2 stage B1 with baffle step correction between the stages. Please see attached diagram. I have built the B1 with LSK170 and I am very happy with it. For this project I wanted to use BF861B's (Vds max 25V, Ptot 250mW max, yfs 16-25mS), selected for about 10mA Idss, upper JFET Idss a bit greater than lower as per post #35.
In practice, R1 in the comp network would be DIP switched series resistors of 1K, 2K, 4K and C1 DIP switched parallel caps of 0.01uF, 0.015uF and 0.022uF. This should give a nice set of possibilities with fz about 300Hz to 2kHz and A 0dB to about -6dB.
As you can see, I was intending to DC couple the two followers - the 9V (approx) bias is already there for the 2nd stage.
Any comments before I commit to making this would be appreciated. Will it work?
Thanks.
Old 9th August 2018, 01:27 PM   #90
Some snaps of the existing B1 out of interest... would just swap the main perfboard out for a new one.
Pass B1 pre with BF862Hide this!Advertise here!
Pass B1 problems jakepro Pass Labs 10 11th October 2016 06:32 PM
Multichannel Mezmerize B1 or Pass B1 ORNJ Pass Labs 9 11th August 2015 12:04 AM
I m too not sure about my pass b1 murphythecat8 Pass Labs 94 6th May 2014 09:35 AM
Mesmerize B1 vs Original Pass B1 - please guide me! KT Pass Labs 9 6th September 2012 05:57 PM
Wanted: Pass B1 macnugget Swap Meet 2 21st April 2011 02:11 PM
