Great price on IRFP044 - Page 3 - diyAudio
Old 20th March 2004, 04:24 PM   #21
Leadbelly
It honestly depends on the bias you'll be running but with extrusions that long I think you should be able to get away with 2 devices per sink if you keep the dissipation per device reasonable like 20W and under for each device. I'd suggest you get yourself a decent power resistor and mount it on the heatsink (use thermal compound) and run a test to see what the temperature rise over ambient will be for a given dissipation. With a 20v supply and a 50w 1 ohm resistor it will dissipate 20w, bolt that to the sink and see how much the temperature will rise over ambient, that will give you a decent idea. Try to keep your design at no more than 50-55 degrees C when running to help reliability and also saftey if you have children or pets.
Kevin
Old 20th March 2004, 04:35 PM   #22
Leadbelly
Just looking over your figures that's a fair amount of dissipation, I'm guessing that you are looking to make a pair of mono amps with 5 sections of this heatsink per side?
That may work just fine but I's seriously test a sink first to see what they will handle.
Kevin
Old 20th March 2004, 04:46 PM   #23
leadbelly's Avatar
Leadbelly
Kevin
That's just it, they're not extrusions, the fins are epoxied on to the base. I don't know whether to expect them to have a similar coefficient to an extruded sink.
I was planning to make a stereo amp, common PS supplying 20A total, each channel using 5 of the heatsinks.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 20th March 2004, 05:12 PM   #24
Yep.....forgot about the epoxied fins LOL
I think you'll be better served being slightly less ambitious, remember that if you are using groups of 5 fets that is 20 fets per channel running 10A total bias?
So 4 devices per heatsink at around 72W per sink, this will give you a temperature rise of 50 degrees over ambient if you run with 10A bias assuming the heatsinks are as good as this particular extrusion Thermaflo example
have a look and maybe you'll revise your plans
Kevin
Great 400Watt Low price amp James82^_^ Vendor's Bazaar 3 22nd March 2007 01:36 PM
FS Gainclone Great Chassis, Potted toroidal, great sound PHilgeman Swap Meet 4 2nd May 2006 01:20 PM
WTB a few IRFP044's kapnk Swap Meet 1 12th May 2005 12:26 AM
Copyright 1999-2017 diyAudio
