Projects to use these power supplies: suggestions please!
Old 14th March 2017, 05:23 AM   #1
VictoriaGuy is offline VictoriaGuy  Canada
Default Projects to use these power supplies: suggestions please!
While waiting for delivery of my toroid power transformer for the Aleph J project, I started digging into my parts collection....
I found these power supplies- two of them- at the back of the shelf:
24v DC @5 amps (regulated)
The transformers are Hammonds:
225VA
Pri: 115/230v
Sec: 55v c.t.
So if necessary, I could re-wire the primaries to get 27.5 v c.t., I suppose.
What's a good (Class A) (beginner/intermediate) project that could put these to good use? A ready-made PCB isn't necessary, but a PCB layout would be an asset.
Thanks!
Old 14th March 2017, 05:35 AM   #2
BesPav is offline BesPav  Russian Federation
Drop your fear and build this:
http://www.amb.org/audio/beta24/
http://www.amb.org/forum/beta24-in-p...ss-a-t396.html
Old 14th March 2017, 05:45 AM   #3
Thanks for the very quick reply and for the suggestion.
I'm not afraid, but I'm 'on a budget' ... .. and that does look like a bit 'rich' project....
I'm wondering how my power supply parts will work with that amp, which requires +/- 36 v regulated. Also wondering about the VA limit...
Later....<edit>....
Reading in your 2nd link I see for the 'Class A version':
The output stage unregulated power supply voltage needs to be dropped in half, from 30V to 15V, fully loaded. This means using a 12V+12V power transformer (or 24V CT). It should be rated 350VA if using a single transformer for both channels, or use one 200VA transformer per channel. As a consequence of the reduced voltage, the 10000uF bulk capacitors' voltage rating could also be reduced from 50V to 25V. You can use higher capacitance if you wish.
So this would work with my re-wired transformer 27.5v CT...and I'd just build a smaller supply for the +/- 24 v regulated
The σ22 regulated power supply should be configured to output 24V instead of 36V. The recommended power transformer is thus changed to 25V+25V or 50V CT, rated 30VA if using a single transformer for both channels, or use one 15VA transformer per channel.
Last edited by VictoriaGuy; 14th March 2017 at 05:56 AM. Reason: Followed the links and did a bit of reading
Old 14th March 2017, 05:57 AM   #4
Dennis Hui is offline Dennis Hui  Canada
Hi VictoriaGuy,
What about an ACA running on 24VDC rail?
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 14th March 2017, 06:16 AM   #5
You are welcome!
Yup...
Being "on a budget" you can build Pass F5, or even composite it with some opamp like this:
Common Emitter OPS?
Projects to use these power supplies: suggestions please!Hide this!Advertise here!
Capacitor suggestions for a couple refurb projects saabracer23 Solid State 47 28th November 2014 02:59 PM
Power supplies to fuel some wild projects n3szd Power Supplies 3 18th April 2013 05:40 AM
Modifications suggestions for The Twisted Pear Power Supplies Joshua_G Power Supplies 4 12th November 2008 11:36 PM
suggestions for 3 projects please musicamex Tubes / Valves 0 21st September 2006 02:52 AM
Shielded center/mains projects. Any suggestions? manxam Multi-Way 1 5th January 2004 02:49 AM
