BOSOZ balanced pre - for novice - questions
Old 3rd May 2018, 09:25 AM   #61
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
bulb tester is exactly for not loaded PSU , and lightly loaded , as is case with preamp
you can't use it only with complete A class amp , which is heavy load and result is big voltage sag across bulb
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 3rd May 2018, 09:32 AM   #62
andrea7617 is offline andrea7617  Italy
Thank you Zen Mod.
So my PSU is ready to be tested!
Old 5th May 2018, 03:26 PM   #63
I tested the PSU yesterday and it works!
I start the main PCB now!
Old 15th May 2018, 08:39 AM   #64
Default Main board - test
Hallo,
after PSU I'am building the main board. I would test it as Nelson Pass says
On the main board the Drain (case) of Q1 and Q2 should be about +30
volts. The Gates of Q1 and Q2 should be at ground. The Source pins
of Q1 and Q2 should be about -3.5 volts or so.
First question:
may I test main board without connect potentiometer? I use input potentiometer, no output potentiometer, fixed resistor for gain (P5).
Second question:
Shall I measure voltage of Q1 and Q2 referring to ground?
Sorry for my stupid questions
Thank you
Old 15th May 2018, 10:28 AM   #65
Zen Mod's Avatar
-yup
-yup
Old 15th May 2018, 12:57 PM   #66
Originally Posted by Zen Mod View Post
-yup
-yup
BOSOZ balanced pre - for novice - questionsHide this!Advertise here!
Novice dreams and novice questions tatagatha Chip Amps 34 2nd October 2016 08:23 PM
BOSOZ and balanced headphones.... Russellc Pass Labs 2 5th December 2015 03:04 PM
A few questions from a total novice. bonescan Tubes / Valves 13 24th March 2009 08:14 PM
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
