BOSOZ balanced pre - for novice - questions
Old 6th December 2017, 12:19 PM   #41
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
yup
cable with RCA on source side , and XLR on pre side , where pins 1 & 3 are shorted
RCA hot to XLR pin 2
RCA gnd to XLR pins 1&3
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 6th January 2018, 02:35 PM   #42
andrea7617 is offline andrea7617  Italy
Default Toroidal blow
Hello, I have a problem. I need your help.
I have done the power supply circuit and I have tested it as Nelson described in his article using 15 kohm load for each channel. The problem is that toroidal get a damage. When turn on the power I heard a little hum from power transformer for a few second and after silence. So I have smelt the bad smell of plastic. I turn off the power, I waited some minutes. I heard some crakling from the toroidal thath were hot...Some ideas???
Old 6th January 2018, 02:44 PM   #43
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
Haven't you swapped primary/secondary sides of toroid accidentally?
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 6th January 2018, 02:47 PM   #44
Zen Mod's Avatar
Originally Posted by andrea7617 View Post
......Some ideas???
none , without more info ....... hopefully pictures
Old 6th January 2018, 03:48 PM   #45
Gyuri: no, after connecting toroid to power supply I check te correct tension without load and it was about 56 V.
May the transformer be not damaged? How can I check it?
Zen Mod: I'll post some picture soon.
Old 6th January 2018, 03:56 PM   #46
Zen Mod's Avatar
what's resistance reading of primary ?
15K is pretty much as nothing at all , regarding load
so - either you made a mistake , or xformer was deffective
no third possibility
Old 6th January 2018, 04:02 PM   #47
I checked load with tester before turn on circuit.
I'll do some detailed pictures from pcb with components.
Old 6th January 2018, 04:33 PM   #48
Zen Mod's Avatar
if nothing else , that will teach you to always use proper mains fuse and to use bulb tester , as long you're newbie in this hobby
Old 6th January 2018, 05:30 PM   #49
Gyuri's Avatar
I do not consider myself as a novice, yet I can make great mistakes.
(Although married only once.)
So do not give up!
Old 6th January 2018, 08:03 PM   #50
I think I have found the mistake. I have done a mistake with the connection of the secondary. There are 4 wire; in the trafo there is a write: sec 60V - Red/60V - Brown/60V. For each channel I have connected one wire red and one brown. I think thath the correct way is 2 wire red for one channel and 2 wire brown for other channel. I tested now the trafo and it seems work: without load I have mesured 65 V between 2 wire of the same color... Now I dont'know how to do. How can I check components of power supply? Are they broken/burned? May I try to test power supply as is using a fuse?
BOSOZ balanced pre - for novice - questionsHide this!Advertise here!
Novice dreams and novice questions tatagatha Chip Amps 34 2nd October 2016 08:23 PM
BOSOZ and balanced headphones.... Russellc Pass Labs 2 5th December 2015 03:04 PM
A few questions from a total novice. bonescan Tubes / Valves 13 24th March 2009 08:14 PM
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
