BOSOZ balanced pre - for novice - questions
Old 25th January 2017, 11:31 AM   #11
andrea7617 is offline andrea7617  Italy
In the image there is the solution without P3-P4 using 5k resistors soldered on the board to XLR out.
P5 should be changed with fixed resistor that, added to R15, gives the gain.
In this case I may use only pot in the input.
Is it correct???
Old 25th January 2017, 12:01 PM   #12
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
post your reference schematic and proper picture of pcb
your sketch in #10 is not good interpretation of what I meant
imagine that these 5K fixed resistors are substituting 5K pots , set on max.
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th January 2017, 12:20 PM   #13
Yes, 5K fixed resistors sobstitute 5K post. I understood it in this way.
Old 25th January 2017, 12:23 PM   #14
Zen Mod's Avatar
so that means - solder resistor on top and bottom pot pcb pads
take output signal from top pot pcb pad , or take it from wiper pad , but short wiper and top pads
as you sketched it , you're having 5K series (to signal) resistors ...... and that's wrong interpretation
Old 25th January 2017, 12:35 PM   #15
Old 25th January 2017, 12:40 PM   #16
Thank you Zen Mod.
This should be correct...Each resistor has one leg soldered on top pcb and other leg soldered on bottom pcb. So each out signal hole is shorted with 5k fixed resistor.
Finally I solder the signal cable on the top (or bottom, it's the same) of the out connection on the pcb to the xlr. May I do the same thing (put 5k resistor) with the ground connection thar link pcb to xlr?
Old 25th January 2017, 12:58 PM   #17
Zen Mod's Avatar
you're getting it wrong
as I said :
this way I can't help you , because I'm not familiar with that pcb and I can just guess what P5 is and what proper pcb pads are
Old 25th January 2017, 01:05 PM   #18
I will use the same pcb of Nelson Pass https://www.passdiy.com/project/prea...zen-line-stage
Old 25th January 2017, 01:30 PM   #19
Zen Mod's Avatar
replace R11 and R12 with 5K values (instead of 100K)
connect +Out pcb pad to XLR Pin 2
connect -Out pcb pad to XLR Pin 3
connect GND to XLR pin 1
in place of P5 - you can temporary use either pot or trimpot , and when you set gain adequate for your needs , measure it and replace with fixed resistor(s)
Old 25th January 2017, 01:32 PM   #20
Great!!!
Thanks a lot!!!
BOSOZ balanced pre - for novice - questionsHide this!Advertise here!
Novice dreams and novice questions tatagatha Chip Amps 34 2nd October 2016 08:23 PM
BOSOZ and balanced headphones.... Russellc Pass Labs 2 5th December 2015 03:04 PM
A few questions from a total novice. bonescan Tubes / Valves 13 24th March 2009 08:14 PM
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
